my car is running like crap!!!! (HELP)(HELP)(HELP)
Old Aug 4, 2004 | 10:55 PM
The Emperor's Avatar
my car is acting up ever since i installed my new clutch..i went for a test drive then my car started to stumble and my idle just went worse..my car could not pass 3000rpm..my car would sound like a WRX with an aftermarket exhaust!!! So then i went to my mechanic then it showed that i have a P0301 Misfire code 1st cylinder!..we changed the spark plugs and it is the same..my car would not even run anymore..its like dying on me.. my mechanic said that it could be my spark plugs, fuel injectors, or my wire harness...so i am taking it to mitsubishi tomorrow and see what they have to say about this..
will the re-flash from mitsu fix this problem? i have 24700 miles..
Old Aug 4, 2004 | 11:38 PM
EvolvedDSM's Avatar
Was everything plugged back in? Specifically, the MAS plug...
Old Aug 4, 2004 | 11:57 PM
yes..everything is plugged in. i hope
Old Aug 5, 2004 | 01:34 AM
EvolvedDSM's Avatar
Well, if it's plugged in, the next thing to look for would be a boost/intake leak. Check all your intercooler fittings, etc... The other obvious thing would be to make sure the fuel injectors and plug wires are all secure.
Old Aug 5, 2004 | 01:53 AM
Sentinal's Avatar
or you could try checkin tire pressure... lol im wayyyyy to bored and tired right now woot bump
jaimeptwo
Oct 8, 2014 03:09 PM
nellynellz
Aug 23, 2011 06:58 PM
Black-X
Dec 22, 2008 02:24 PM
IslandEvoIX
19
Apr 28, 2007 01:44 AM
FeRRarI eAtR714
25
Dec 20, 2005 10:34 PM
