Sun Automobile Hyper Voltage System Review
Subscribe
Aug 8, 2004 | 11:28 PM
I was at Super Autobacs today and had a some money burning a hole in my pocket so i picked up the Hyper Voltage System. The Install took about five minutes, all you have to do is add a wire to each battery terminal and find a place to mount the box. Now for the important part. The car idles much smoother with the box installed and there is a noticable increase in off boost power and the car feels smoother and more powerfull from 5000 rpm to redline especially in 3rd, 4th, and 5th gear. I definitely recomend this product, it not only feels more powerfull but the car is more drivable with the extra low end grunt.
Reply 0
Aug 8, 2004 | 11:51 PM
it is a very good product, but alot of people still saying it is useless.
Reply 0
Aug 9, 2004 | 12:06 AM
how much did you pay for it?
Reply 0
Aug 9, 2004 | 06:19 PM
it was $188. to me it is well worth the extra drivability.
Reply 0
Aug 9, 2004 | 07:15 PM
Quote: I was at Super Autobacs today and had a some money burning a hole in my pocket so i picked up the Hyper Voltage System. The Install took about five minutes, all you have to do is add a wire to each battery terminal and find a place to mount the box. Now for the important part. The car idles much smoother with the box installed and there is a noticable increase in off boost power and the car feels smoother and more powerfull from 5000 rpm to redline especially in 3rd, 4th, and 5th gear. I definitely recomend this product, it not only feels more powerfull but the car is more drivable with the extra low end grunt.
where u mount it? i stick it on the side of the battery.
Reply 0
Aug 9, 2004 | 07:18 PM
I mounted it on one of the stock intake mounts.
Reply 0
Aug 9, 2004 | 07:20 PM
Why are you having drivability problems with your Evo? Did you have a problem before?
Reply 0
Aug 9, 2004 | 07:21 PM
I assume this works by regulating the voltage so you always get a constant 12volts or does it work like a grounding kit?
Reply 0
Aug 9, 2004 | 07:24 PM
I didnt have drivability issues, it just made it better. it feels like the car has more off boost power which makes for less shifting.
Reply 0
Subscribe
