EGT on EVO
Old Aug 9, 2004 | 01:23 AM
Yaroslav's Avatar
Question EGT on EVO
I KNOW THAT OUR CARS NOT FOR HIGHWAYS, BUT NOT THAT MUCH!!
TODAY I RAN ON HIGHWAY WITH BOOST 1.3 ON EACH GEAR, AND IN 5 MINUTES EGT WAS 970-980c!!!! And my friend which was behind me said there was a fire from exhaust, for about 4 seconds!
Do you have the same problems?
May be it will help
MODS:
1)TURBO-BACK
2)COLD SPARKS
3)R-SPL INTERCOOLER
4)POWER FC (D-JETRO) with base settings
5)ARC intake
6)HKS BOV
7)WALBRO 255 FUEL PUMP
8)APEXI AVC-R
Old Aug 9, 2004 | 01:27 AM
ez76's Avatar
how did you tune your car?
Old Aug 9, 2004 | 01:29 AM
ImportUpgrade's Avatar
too much fuel I am guessing, get ur car tuned - that might help.
Old Aug 9, 2004 | 01:35 AM
bryans2k's Avatar
900 c is usually ok, but fireball for 4 secs? I would wonder either too rich or too cold of spark plugs...
bryan
Old Aug 9, 2004 | 03:40 AM
Ninj0x's Avatar
I find that if I run my car hard I can get temps of 1200c and my car is stock except for a cat-back and down pipe.
Old Aug 9, 2004 | 04:01 AM
4ce fed's Avatar
1200C? Where's your EGT probe? In the cylinder? That's hard to believe, unless you also tell us that you've melted some valves or something. Even if you aren't having any problems, running that hot isn't a good idea.
Old Aug 9, 2004 | 04:38 AM
Ninj0x's Avatar
It's on the manifold port #2. It could be a misreading but, Ive seen it acouple of times and my car is pretty stock, so I thought it was normal. It doesnt happen much, only when I get on it after its been on for a while. And there hasnt been any decrease in performance.
Old Aug 9, 2004 | 05:10 AM
MalibuJack's Avatar
ITs not so much a decrease in performance, but 1200 degrees is enough to melt the pistons so its likely a misread.. If your belching alot of burning raw gas through the exhaust manifold you could also get very high EGT's...
TTP Engineering
Evo 'For Sale' Interior Styling
141
Jun 3, 2010 10:21 AM
TTP Engineering
May 22, 2009 09:52 PM
TTP Engineering
62
Apr 24, 2009 03:26 PM
tsherriff
Nov 9, 2006 03:33 PM
Sicktght311
Lancer Engine Management / Tuning Forums
13
Aug 21, 2006 12:42 PM
