tranny fluids
Old Sep 7, 2004 | 01:06 AM
titaniumkingpin's Avatar
tranny fluids
i want to change my tranny fluid. need help...what should i use? how hard is it?
cant find a write up..... thanks anybody.
Old Sep 7, 2004 | 01:15 AM
ReHeat's Avatar
see this thread
http://www.norcalevo.net/forums/view...t=transmission
Old Sep 7, 2004 | 02:22 AM
what should i go with for my lube?
company?
i want to change rear diff. + transmission+ transfer case
anyone have suggestions?
Old Sep 7, 2004 | 12:50 PM
someone must know what type of lube is good for the evo
93civEJ1's Avatar
yeah the search bar knows.
but no really... Alot of guys are recently going back to stock Diaqueen fluids in the diffs. The tranny is another story. Pennzoil Synchromesh, BG Synchroshift, GM Synchrmesh, Redline MT-90, etc.
Old Sep 7, 2004 | 02:14 PM
bolsen's Avatar
To this guys credit, there are soooo many topics out there than it's very tough to get a definite answer.
I am doing Pennzoil Syncromesh in the tranny. (I originally bout BG Syncroshift, but I later found out it's the stock stuff.) As for the diffs, I am hesitant about running Redline because it seems to eat up more things than it helps.... so I'm waiting on that.
So that's what my current stock plans are.
Old Sep 7, 2004 | 02:18 PM
2k4EvoVIII's Avatar
Im using BG Synchroshift in the tranny and Redline Shockproof HEAVY in the Transfer Case and Rear Dif. Will see how it works i guess.
Chris
Old Sep 7, 2004 | 03:16 PM
i think im going to go with pennzoil syncromesh for the tranny but still not decided on the transfer case or rear diff.
Old Sep 7, 2004 | 03:21 PM
EVOTEXAS's Avatar
Redline MT-90 in the tranny and either stock SAE90 or Royal Purple SAE90 in the transfer case and rear diff. People with Redline problems were/are putting the wrong fluid in the car. You have to select the proper product, whichever brand you go with.
Old Sep 7, 2004 | 06:35 PM
bolsen's Avatar
Well just put in the penzoil stuff tonight... I'll drive it more tomorrow
Old Sep 7, 2004 | 06:48 PM
sr20det91's Avatar
Out of curoisity, did the bottle of pennzoil syncromesh that you used have the weight listed on it. I recently changed my tranny fluid, and the bottle I used had no weight or GL rating listed on it, but according to the tech line it was good to go for the Evo.
I dunno, its been in there for about 1000 miles and everything seems to be working fine, but I just wanted to make sure I didnt get the wrong type fluid.
Old Sep 7, 2004 | 08:50 PM
correct me if im wrong but i think the pennzoil synchromesh has only type of fluid.
I'm just ordered the synchromesh and redline 75w90 for rear diff and transfer case.
Old Sep 7, 2004 | 09:19 PM
bolsen's Avatar
Nope, no markings just compliance stuff
Old Sep 8, 2004 | 12:19 AM
SinCityEvo's Avatar
I have been running GM synchromesh in the tranny w/o problems and it shifts so much better.
After searching and reading many threads that confused me on the TC and rear diff fluids, I decided on OEM fluids for my next change. You can't go wrong. Diaqueen LSD gear oil. $60 for a 4 liter can from my dealer.
Jovan Caro
Jan 23, 2017 08:31 PM
cec12789
14
Oct 6, 2009 07:36 PM
orangeorphan
Jun 4, 2009 07:33 PM
evo9ben
Sep 1, 2008 03:19 PM
S6devil
May 7, 2008 09:31 AM
