is this where you tapped boost from?
Old Sep 10, 2004 | 02:44 PM
titaniumkingpin's Avatar
i have an autometer ultra lite. (without vacum reading)
is there where i tap my line?
Attached Thumbnails is this where you tapped boost from?-fuelpressure_bosst_tap.jpg
Old Sep 10, 2004 | 02:55 PM
tokeone's Avatar
if thats the line thats coming off the throttle body back to the throttle body... YES!
although ive seen people tap the line thats off the BOV. the throttle body is the best place to get an accurate reading from
added a pic of mine (from the factory)
hope that helps if yours is diferent
Old Sep 10, 2004 | 02:58 PM
4ce fed's Avatar
Is that the line that goes directly to the FPR? If so, it'll work, but not exactly correct. See here: https://www.evolutionm.net/forums/sh...ad.php?t=96614
Edit: Although, since you have just a boost gauge, it might be fine. Not sure what the FPS does under boost while the ECU keeps it closed for vacuum.
Old Sep 10, 2004 | 03:36 PM
Evil_1's Avatar
My factory optional boost guage that came from the dealer was tapped exactly like the image tokeone attached.
Old Sep 10, 2004 | 03:51 PM
MYEVOVIII's Avatar
You should tap the vacuum line right off the intake manifold before FPR, it needs to be before the fuel pressure solenoid since you could get incorrect results from the solonoid.
Just like 4ce fed said . everyone I know who has tapped it after the FPR has incorrect psi values and did not know it until they went to the Dyno day and got psi readings several cars showed higher psi than they where actually making
Old Sep 10, 2004 | 05:01 PM
inline4g63's Avatar
i agree with 4ce fed and and myevoVIII.
tiesto14
Aug 9, 2016 05:20 PM
black_beauty
10
Feb 5, 2013 01:34 PM
spyderefs
Nov 5, 2006 04:46 AM
PHiSH
14
Aug 26, 2004 03:09 PM
Dookie
Lancer Aftermarket Forced Induction Tech
10
Jul 12, 2004 02:00 PM
