Weird sound coming from engine
Old Sep 20, 2004 | 05:42 AM
x7eVoLuTiOn7x's Avatar
Im hearing this weird sound like my piston is hitting the valve cover when the engine is cold. After it gets hot, the sound goes away. This wasnt happening before i did my oil change using 15W-50 fully synthetic oil. Is this normal?
Old Sep 20, 2004 | 06:10 AM
propellerhead's Avatar
Doesn't sound normal. Why are you running 15W-50?!? What is the correct oil viscosity called for over there for the 7? I realize that it gets pretty hot over there but no hotter than where I live (during the summer) and we run Mobil1 10W-30 as spec'd for the 8. Do you have an oil pressure gauge? I bet if you did it would be pegged or indicating MUCH higher oil pressures, especially when cold.
Besides, where your living, I doubt you need such an extended viscosity range. Extended viscosity range oils just wear out more quickly.
Old Sep 20, 2004 | 06:21 AM
JVBEvo5's Avatar
I just had an oil change and I am running 10W-30 Mobil 1 synthetic for the first time. I used to use 15W-50 because of the heat of where i live. But the thing is, when the car gets hot. It stalls when I am in idle. Its like i have bad gas but I don't.
Old Sep 20, 2004 | 09:49 AM
Dunno. I'm going to guess that the hydraulic lifters like a certain oil viscosity. You probably wouldn't have any issues if you were using solid lifters and shims.
Old Sep 20, 2004 | 10:05 AM
GOKOU's Avatar
Sounds like lifter or valve noise to me which should be normal.
Old Sep 20, 2004 | 10:08 AM
2k4EvoVIII's Avatar
Its the hydralic lifters. A known problem with Mitsu. It doesnt hurt anything though just takes some time for them to fill up with oil is all.
Chris
Old Sep 20, 2004 | 12:23 PM
marksae's Avatar
Why did you switch to thicker oil? Do you live in a cold environment? Like others have mentioned earlier, that noise is your lifters and is not big deal. They've been ticking like that ever since the 1g DSMs. There are three versions of the lifters that were used on the DSMs. I'm not sure if Mitsu has revised the design for the EVOs or not.
Old Sep 20, 2004 | 12:41 PM
watchout's Avatar
If it sounds like it is coming from the rear of the engine where the intake manifol is then it is your lifters. It will sound like a loud clicking noise. Known problem with DSM's and now Evo to. Oh well.
Shane
Old Sep 21, 2004 | 03:58 PM
Oscar's Avatar
I agree, it seems those are you hydraulic lifters. That normaly happens when using a thicker oil due the longer time used to fill lifter chambers and remove trapped air (once hot it´s faster). Why 15W-50?...use the recommended 10W-30, 5W-30 or 0W-30 (Castrol RS)
Old Sep 21, 2004 | 04:06 PM
Az3ar's Avatar
Chris
Once again, Mitsu has dropped the ball. Good job Mitsu, it’s like we are ****** waiting to get f@#$
Old Sep 21, 2004 | 04:08 PM
value's Avatar
How about the dreaded clutch rattle ? Jump in the car and see if you can still hear the noise. If you can push in the clutch and see if it goes away.
Old Sep 21, 2004 | 05:52 PM
marksae's Avatar
haha.. damn man, I know you got a grudge against mitsu, but lifter noise isn't really a "problem" since this guy's noise was induced by him using a thicker oil. For those of us who use the factory recommended 10W30 Mobil 1, the noise isn't even an issue.
Even with the older lifters, the noise seemed to always go away after putting in some Mobil1. Thinner oil does help too.
Old Sep 21, 2004 | 05:56 PM
watchout's Avatar
I have also been using 15W 50 "performance driving" Mobil 1. I got it for a little extra protection. My buddy uses 10W 30 and you can hear lifters in his car once in awhile also. I just think some cars do it and some don't.
Shane
Old Sep 21, 2004 | 06:48 PM
Nad1370's Avatar
Hey!!!..
I was wondering what I was hearing over the weekend. Same thing , goes away when I press the clutch slightly.
First time I heard it after 19,900 miles.
After doing some spirited driving...... WHALLAH!!! hasn't come back yet. knock on wood.
Old Sep 21, 2004 | 07:02 PM
SuperchargedGTZ's Avatar
it is the hydraulic lifters....i have had this problem since day one...once the car gets warm it goes away...it is lick a ticking noise right.
