Check engine light affecting performance?
Old Sep 20, 2004 | 11:18 AM
SterlingEvo's Avatar
Originally Posted by caymandiver75
Glad i could help Steve Are you also getting a CEL?
I have on and off a couple of times... currently off for about a month. I've always let it turn off by itself, to make sure I wasn't masking a potentially worse problem. I am going to get the O2 sim, though... it seems to be the thing to do
Old Sep 20, 2004 | 02:09 PM
berkel's Avatar
mikesevo8:
mind elaborating a bit more on that spark plug anti foul adapter trick. I'm interested in know how to do that. Maybe I could even give it a try before putting the O2 simulator on.
This is my plan if the code comes back.
It's a mechanical solution to the SES light. It basically moves the O2 sensor tip "up" so it "sees" less of the exhaust stream and doesn't trigger the cel. Pretty ingenious! The trick involves getting the appropriate sized anti fouler thingy, and threading the o2 sensor into that. There is a recent thread on this. I believe it was inspired by a mechanical solution that a vendor uses with their test pipes...
Take care,
FB
Old Sep 20, 2004 | 03:00 PM
caymandiver75's Avatar
what is this anti fouler thingy? Spark Plug Non-Fouler?
Old Sep 20, 2004 | 08:01 PM
mikesevo8's Avatar
mikesevo8:
Here is the link with pics.
https://www.evolutionm.net/forums/sh...ad.php?t=62524
Start at post #14
Like I said, works for me.
I reference this thread so much, I should put it in my sig.
Old Sep 27, 2004 | 12:19 PM
Noize's Avatar
EvoM Administrator
but disconnecting the battery to get rid of the code will cause the ECU to be out of wack as it takes about 200 miles to adjust itself once again so you will feel a power loss for the 1st 200 or so miles.
This information isn't quite right. The ECU is much more adaptive than you are giving it credit for. While I was custom tuning an Evo this weekend with an SAFCII, it threw a P0300 (has been since it was new). I did a reset, and the car went pig rich on the first run. The immediate next run after that, the ECU had already adapted and made identical power to the run prior to the reset.
This particular car was a Buschur Stage 2, and made awesome power for its level of mods.
Old Sep 27, 2004 | 08:45 PM
egui42's Avatar
I have been throwing the same code to from Buschur 3" exhaust. Jim Buschur says the cat is way to free flowing. The sensor thinks it is a bad cat. Sent me an o2 simulator to solve the problem. Haven't put it on yet, but will let you guys know if it fixes the problem.
Old Sep 29, 2004 | 05:17 PM
**UPDATE**
Just got the Buschur O2 simulator installed and it appears to be working properly (blinking red) Since buschur racing didn't give me a long enough grounding wire and I wasn't about to drill into the floor board, I had to go and get some extra wire and lengthen the grounding wire. I grounded it to a screw on the hand brake under the armrest cover where something else is also grounded. Tucked the wires back in under the carpet leaving the O2 simulator standing out so I can see it under the seat. I sure hope that damn SES light doesn't comes back on in the next 200 miles or so. Wish me luck. I'll post back later after I test it out.
havik65203
Lancer Troubleshooting
Feb 9, 2010 08:38 AM
Big_Mike
10
Dec 4, 2008 11:54 AM
dhahlen
Lancer Engine Tech
13
Aug 7, 2008 11:21 PM
customlancer
10
Mar 2, 2007 01:54 PM
Blue#2
Nov 9, 2003 01:36 PM
