intercooler
Old Sep 20, 2004 | 02:41 PM
steveevo8's Avatar
intercooler
i got a good question for anyone who has a definite answer.. how much power can you be pushing that the Stock Intercooler would still be good for???
Old Sep 20, 2004 | 04:18 PM
evo81's Avatar
about 320-350 whp
Old Sep 20, 2004 | 04:29 PM
rebelzx's Avatar
I'm making 360+ whp on a stock intercooler. Stock IC pipes too. I'm sure there are a few guys making more than me on the stocker.
Old Sep 20, 2004 | 06:11 PM
EVOTEXAS's Avatar
It doesn't mean you can't make more than 350 on the stocker, it means the stocker becomes a bottleneck at 350. You can make 1000 HP on the stock IC if your motor has enough *****. What this means is you won't see a difference from changing the IC until you around these power levels. I bet you could make a significant amount more power if you upgraded yours.
Old Sep 20, 2004 | 08:02 PM
rebelzx's Avatar
I hope so. I'm thinking about buying the AMS intercooler and a TME spec turbo to hit 400 whp without a standalone or piggyback. I might need some headwork to get there though.
Old Sep 20, 2004 | 08:04 PM
vegasboy301's Avatar
go with turbotrix's intercooler. that thing is pimp
Old Sep 21, 2004 | 12:10 AM
kevo's Avatar
Do you have any pictures/ info of the Turbotrix intercooler?? Never heard anything about it.
Old Sep 21, 2004 | 12:15 AM
mitsuorder's Avatar
yeah same here. anyone have info on the TT i/c?
Old Sep 21, 2004 | 12:48 AM
RogueSTi's Avatar
It seems that power can be gained from a intercooler upgrade at any mod level. Even stock. Sure, it's not the first thing you should buy, but if you are even asking this question, you probably need one.
Old Sep 21, 2004 | 01:34 AM
evo sky's Avatar
Not exactly true...
Larger intercooler has a disadvantage, and that is the increased pressure drop... if you are running stock turbo/stock boost, a bigger fmic will most likely hurt performance because the same amount of air is travelling a greater distance
Old Sep 21, 2004 | 01:42 AM
evo sky's Avatar
If american engineered/manufactured FMICs' are so great (I dont want to mention any company names in particular), geez, I wonder why I dont see any japanese evo's spotting american built aftermarket parts, yet at the same time evo owners worldwide are putting japanese parts on theirs
Old Sep 21, 2004 | 06:56 AM
David Buschur's Avatar
EVOSKY,
When was the last time you saw an American vendor building EVO parts and trying to market them in Japan? Japanese flood us with there parts and make them readily available.
David Buschur
www.buschurracing.com
Old Sep 21, 2004 | 07:08 AM
PVD04's Avatar
Actually, several of the larger intercoolers have a lower pressure drop than the stock intercooler. It all depends on which intercooler. The AMS intercooler's largest pressure drop was 1 psi at 24-25 psi. At a lower boost setting, that pressure drop will be even less. Unless someone were to buy a very cheap, poorly designed intercooler, there really isn't much of a downside.
Originally Posted by evo sky
Not exactly true...
Old Sep 21, 2004 | 07:17 AM
Correct, the larger FMIC have LESS pressure drop than a smaller unit. More displacement to fill but less pressure drop.
David Buschur
