whats wrong with my car????
Old Oct 4, 2004 | 11:55 AM
bigmike9726's Avatar
Unhappy whats wrong with my car????
two days ago i went to start my evo (7K miles, turboback with cat delete, stock clutch), and it would crank but not catch....i woke up this morning and gave it another shot and sure enough it started....what could it have been? luckily it was in my driveway and not in the mall parking lot or somewhere, but i want to avoid this happening again, what could it be?
Old Oct 4, 2004 | 02:21 PM
avengerhed's Avatar
worst case... beginning of compression leakage...
maybe (to be not so morbid) it was just flooded? theres a procedure in the manual for starting the car if the engine's flooded.
anyone else have ideas?
Old Oct 4, 2004 | 02:25 PM
Z2EVO's Avatar
when you first went to start it and it wouldnt start. had the car been sitting for a while, had you just driven or what?
twinevo's Avatar
if it's cranking but not catching, it would signal to me that its electrical(spark plugs) or fuel related(maybe fuel pressure regulator)...but there's so many possiblities.
Old Oct 4, 2004 | 04:45 PM
Coolguy949's Avatar
Check your cam angle sensor (the plug above the BOV attached to the head). It could also be a crank angle sensor going out. Check your plugs. Basically check anything electronic attached to the valve cover. Good luck!
Old Oct 4, 2004 | 06:45 PM
Nad1370's Avatar
Flooded...Don't sweat it.
Happens once in a while. Why do you think Mitsu put in the procedure to start it in the manual if gets flooded?
Old Oct 4, 2004 | 06:49 PM
tweakdsm's Avatar
can someone post the procedure???
Old Oct 4, 2004 | 06:55 PM
4Gsixty3's Avatar
HAHA.. i thought flooding only happens to my rx8... (at least once a week)
well hope this will not be the case for my evo.
Old Oct 4, 2004 | 07:40 PM
Nad1370's Avatar
Page 3 - 31
Right from the owners manual:
If the engine has flooded during starting, first run the starter for 5 - 6 sec. while holding the accelerator pedal on the floor.Release the ign. key ( return to the "on" position) and the accelerater pedal. wait a moment , then without depressing the gas pedal, turn the ign. key to the "start" position for another 5-6 sec. Release the ign. keyif the engine starts.
Repeat as neccesary if the engine fails to start, or contact a Mitsu dealer.
Old Oct 4, 2004 | 07:53 PM
GREDDY's Avatar
If it cranked but didn't turnover, this could be related to the starter or fuel pump. If it only happened once, your car probably just had a brain fart. If it's a problem, it would be a consistant problem. Since it only happened once, it shouldn't be a problem.
Old Oct 4, 2004 | 07:55 PM
hueman's Avatar
what does "flooding" mean? water?
Old Oct 4, 2004 | 07:58 PM
jcnel_evo8's Avatar
Flooding means you have too much fuel and too little air to ignite the gas. Yes, there are cases where too much gas won't burn, and then you have to 'pump' it out, or wait til it 'evaporates' off.
jcnel.
cjpty
Oct 25, 2015 04:26 PM
u-gee
Jul 5, 2012 11:39 AM
jackchn152
Jan 30, 2008 06:50 PM
11secEVO7
Nov 20, 2006 09:27 AM
importstylz07
Lancer Troubleshooting
11
Aug 2, 2006 02:59 PM
