Warranty ???
Old Oct 19, 2004 | 05:56 AM
GOKOU's Avatar
Question Warranty ???
I have 03 Blue EVO 8 with BR ST4 setup. Both driver door and passenger door along with the driver side panel sweak like hell. Is this still cover under warranty or will tell me this is normal? Anyone fix the sweaks yet?
Thks
Old Oct 19, 2004 | 06:38 AM
sleet's Avatar
I don't see how performance parts can make doors sweak...so bring it in and see what they say...
Old Oct 19, 2004 | 06:45 AM
hotrod2448's Avatar
Do you have any suspension mods? I could see them trying to say the higher spring rates are transfer more vibration into the chassis and that's whats making them squeak. My passenger side front door squeaks like crazy too.
Old Oct 19, 2004 | 06:48 AM
GOKOU's Avatar
Thanks and I'll give it a try when I bring the car back for the fan recall. No suspension mods. It's sweaking like the window is not tight and slightly vibrating.
Old Oct 19, 2004 | 09:53 AM
hotrod2448's Avatar
Mine is coming from the back edge of the interior door panel rubbing the plastic on the b-post. If I just slightly roll the window down to relieve the pressure on the door it goes away. Watch how much your interior door panel moves when you put the window up. I'ts kind of scary how much it bulges in when the window stops at the top.
Old Oct 19, 2004 | 10:25 AM
GOKOU's Avatar
Did you fix it and what did you do?
Thks
Old Oct 20, 2004 | 01:41 PM
hotrod2448's Avatar
Haven't fixed it, just know where it's coming from. I'm not really sure where to start as far as fixing it goes. Probably not much I can do about it.
Old Oct 20, 2004 | 06:24 PM
vletnguyen's Avatar
um i would take off your boost controller.. they can void the warrenty for "over boosting". but then again. i dont see why engine mods would cause things like sweaking panels or paint issue etc
