My APR front Splitter fell off
Old Dec 7, 2004 | 05:45 PM
chronohunter's Avatar
Originally Posted by eve-slow
Thanks. I didn't know it stuck out that much. Is that the only proper way to install it or can you have it a little more flush with the bumper/lip?
You can re-drill the holes but moving it in reduces the effectiveness of it. The mounts are really flimsy it needs additional support if you'll be going over 80
Old Dec 7, 2004 | 05:49 PM
wmcorcor's Avatar
That hasn't been my experience so far. I used heavier stainless bolts, nuts and washers and NOT the plastic screw/clips from the factory under-tray WITHOUT the rods and mine has been fine over 80.
I'm sure if you move it in the rods won't work but given that there will be less downforce on the pslitter because less of it is exposed I'm sure you'll need the rods even less.
Old Dec 7, 2004 | 05:55 PM
tokeone's Avatar
bad pete!
Old Jan 8, 2005 | 09:30 PM
mr0072003's Avatar
LOL, sory for the delay in replies, been busy. Yeah it looks like the plastice screws were not strong enough. O well I will have to get another one and do the sime fro the sideskirts.
Old Feb 26, 2005 | 03:38 PM
NocturnalEVO's Avatar
Does the bumper need to be taken off to install the splitter?
Or can you install it with the bumper on?
THanks!
Old Feb 26, 2005 | 03:43 PM
beebers's Avatar
Nope the bumper stays on. You only remove the plastic undertray.
Old Feb 26, 2005 | 03:44 PM
thanks
Old Mar 2, 2005 | 03:21 PM
mr0072003's Avatar
THanks!
I found that you have to tkae the bumper off, since there was no way I could screw the nuts on the bolts that hold it to the front bumper. there may be a way to do it without taking the bumper off, it would be a pain in the ***. I hope this helps, and make sure to use washers, as that turned out to be the real reason the splitter fell off.....I am still looking for another cheap used one....any1 know where i can get one, pm me details.
Mulholland0132
Nov 7, 2016 06:58 PM
Bmurray
Oct 9, 2016 07:56 PM
EGbeater
Sep 19, 2016 05:50 PM
yoyo6999
Southeast Region
Nov 6, 2008 08:22 PM
ColdEvolution8
Jun 21, 2008 04:28 PM
