Transfer oil & transaxle oil question.
Old Jan 19, 2005 | 06:54 AM
  #46
RallyRedEVO's Avatar
Might be as simple as a gasket in your exhaust being blown and making the sound, or heat sheild under the car resonating by itself or against something.
Does it only happen when you are in motion, or can you rev the engine to different RPMs while stopped and hear it too?
Old Jan 19, 2005 | 07:18 AM
  #47
EVOQUICK's Avatar
I hope that is it.
A little different sound though- I think
I have not tried reving the engine while parked - will do that when I get home.
Old Jan 19, 2005 | 07:29 AM
  #48
I'm a bit of an auto-hypochondriac as well.
Old Jan 19, 2005 | 08:38 AM
  #49
WagsEvo's Avatar
I used Redline MT-90 in the transaxle. I posted this on other threads, but when Winter hit it got really notchy. I can barely put it into gear for the first 10 minutes of driving. I contacted Redline about the problem, but no response yet. Hopefully there is something I can do to fix to problem.
In any case, if you find other people with good luck using something other than Redline, I'd do that. I won't use this Redline again. Just my opinion though...
Old Jan 19, 2005 | 09:27 AM
  #50
GEARS's Avatar
Well this is what I've have in my shop.
A pile of ring & pinions from the EVO-8 that all have damaged teeth from using the wrong oil.
Time to rebuild a transfer case....
Jon@TRE
Old Jan 19, 2005 | 12:56 PM
  #51
lancerdealer's Avatar
Just to add to the discussion......the MR trans takes an entirely different oil than the regular EVO.
Old Jan 20, 2005 | 09:33 AM
  #52
WagsEvo's Avatar
Redline in Transaxle
Got a response from Dave at Redline. He said to put 2 qts. MTL and one qt. MT-90. This matches the required viscosity better and give better cold weather protection. Plus, it's synthetic like all Redline. I'm just pissed because now I'm going to drain 2 qts. MT-90 to put in the MTL. The work never ends...
Old Jan 20, 2005 | 09:42 AM
  #53
steveevo8's Avatar
When is the best time to change all of your oils.. i had a 15k inspection of my car 6k miles ago... would i be due for another one in the next few thousand. or is it good to do it every ... how many miles is basicly what i'm asking?
Old Jan 20, 2005 | 09:46 AM
  #54
machron1's Avatar
Originally Posted by GREGPOL
Ok
I just called Mitsu dealer and was told they will not sell me their oil.
They say they can only change it in their service dep.
Is that true or is the guy talking bull****
Also, he says that they are using the same oil for transaxle and transfer- ????
I do not want to take my car to Mitsu.
Is there a chance I could buy OEM oil somwhere else or am I forced to put different one in?
Don't listen to that schmuck. The tranny and transfer case fluids are totally different specs. GL-5 in the main tranny is a NO NO! GL-4 in the transfer case is a NO NO!
Old Jan 20, 2005 | 11:18 AM
  #55
GEARS's Avatar
It's cheap insurance to change the drivetrain fluids every 5000 miles.
Old Jan 23, 2005 | 09:26 AM
  #56
EVOQUICK's Avatar
OK it is me again.
Another question.
Does TC make whining noise when spinning wheels (in snow)??
I know it should not make that noise when driving but what about spinning wheels.
It is loud (whines) when I do that.
Is that normal?
Or is that when it is accually trying to do its job?
Please help
This car drives me nuts.
My next post may be in "for sale" forum.
The whole story is I have about 100 miles on new TC and I hear this noise.
Old Jan 23, 2005 | 10:36 AM
  #57
yesevo's Avatar
i had whingin noise due to bad tires (angled all the way round---due to bad ball joint in the rear lower control arm i guess). after change new tires the noise has gone. so chenck the tire first the noise gets loudest at around 25mph ,,,am i right?
Old Jan 23, 2005 | 10:39 AM
  #58
yesevo's Avatar
where can i buy redline oil for transmission? i bougth mobil 1 gear oil for transfer and diff at autozone. cant find redline MT-90 nowhere.
Old Jan 24, 2005 | 07:03 AM
  #59
EVOQUICK's Avatar
bump
Old Jan 24, 2005 | 08:36 AM
  #60
EVOQUICK's Avatar
Going back to Diaqueen SAE 90 - is it safe to use it in low (freezing) temperature?
Should it not be SAE 75 - 85?
