Transfer oil & transaxle oil question.
Old Jan 24, 2005 | 11:17 AM
  #61
GEARS's Avatar
The transfer case heats up quickly enough to use Diaqueen LSD Gear Oil, part # 3775610 without much of a problem.
If you are concerned about the oil being too think in artic temp zones you may want to drive at speeds below 45mph for 5-10 miles to warm things up before jumping on the highway.
Old Jan 24, 2005 | 11:56 AM
  #62
Evoisdream's Avatar
so the diaqueen goes in the tc and dif? or tc and tran? what goes in the 3rd one thanks
evoisdream
Old Jan 24, 2005 | 12:10 PM
  #63
GEARS's Avatar
evoisdream
Just fill the transfer case with Diaqueen and let the transmission do the rest.
The transfer case has 2 oils inside of it that are separated by a bunch of oil seals to keep the two oils from mixing.
Diaqueen LSD Gear Oil to lubricate the ring & pinion in the transfer case.
The front differential is also located inside the transfer case, yet it is sealed off from the ring & pinion inside of a sealed metal housing, and it receives oil from the transmission by way of an oil feed passage that allows the oil to pass through and lubricate the front diff. From there this oil flows back into the transmission.
More on this can by found by using the all mighty search engine.
Jon@TRE
Old Jan 25, 2005 | 07:58 AM
  #64
WagsEvo's Avatar
Originally Posted by WagsEvo
Got a response from Dave at Redline. He said to put 2 qts. MTL and one qt. MT-90. This matches the required viscosity better and give better cold weather protection. Plus, it's synthetic like all Redline. I'm just pissed because now I'm going to drain 2 qts. MT-90 to put in the MTL. The work never ends...
I drained only one quart of the MT-90 out last night and put in one quart of MTL. WOW, what a difference. Smoother shifting already. Even when cold there is smoother shifting and a dramatically different feel on the stick. I think when it warms up there will be an even bigger difference.
Thanks to Dave at Redline for the suggestion.
Old Nov 13, 2008 | 06:40 PM
  #65
evo6gsrpanama's Avatar
I've just messed my transfer case up using Redline, guys never use it!
Old Nov 13, 2008 | 06:57 PM
  #66
Well I've read the whole threat...
What do you guys recommend.
GL4 for what and quantity? what brand?
GL5 for what and quantity? what brand?
Royal Purple you can use the same on both?
I'm really confused...
Thanks
Old Nov 14, 2008 | 11:02 AM
  #67
Jeff_Jeske's Avatar
Is it really worth the $3000 risk to use some aftermarket oil? I'd say no.
I buy all my fluids from www.mitsubishiparts.net
5 SPEED (W5N51)
- Gear Oil API classification GL-4 SEA 75W-85 or 75W-90
- Diaqueen M/T Fluid - MZ313376 (1gal)
- capacity 2.9 qts
6 SPEED (W6MAA)
- Diaqueen Super Multi Gear 75W-85 or exact equivalent
- Diaqueen M/T Fluid - MZ313376 (1 gal)
- capacity 2.3 qts
Transfer Case
- Mitsubishi Limited Slip Differential Oil (LSD) or equivalent
- Diaqueen LSD Fluid - 3775610 (1 gal)
- capacity 0.63 qts
ACD Operating Fluid
- Diamond ATF SP III - ACH1ZC1X05 (1 qt)
- capacity 0.95 qts
Rear Differential
- capacity 0.58 qts
Mitsubishi Coolant
-MZ311986 (1 gal)
Mitsubishi Brake Fluid
-DOT 3
-MZ311987 (354 ml)
Mitsubishi Power Steering Fluid
-ACH1ZC1X04 (12 oz)
Oil Filter
-MZ690116
Old Nov 14, 2008 | 05:23 PM
  #68
njboy's Avatar
^^^^^^^^^^ YES....Use only these oils and you'll be happy.....^^^^^^^^^^
Old Nov 14, 2008 | 05:35 PM
  #69
Wicked E's Avatar
The ONLY fluid I would use other than OEM is Amsoil MTG in the tranny.
-E
Nex1
Toronto Lancer Club
Jun 3, 2010 10:10 AM
dragon831
Mar 12, 2010 05:56 PM
JT-KGY
Jul 1, 2005 05:37 PM
eve-slow
Jun 11, 2005 08:26 PM
EvoV
Jan 18, 2003 06:53 PM
