MR FQ400 top gear time (forget the other thread)
Old Dec 27, 2004 | 04:22 AM
  #121
wrcevo's Avatar
What do mean that u cun do anything with the car? U just need to be in the right gear at the right time. =)
Old Dec 27, 2004 | 04:24 AM
  #122
wrcevo's Avatar
What do mean that u cun do anything with the car? U just need to be in the right gear at the right time. =) The FQ-400 is not for noob drivers
Old Dec 27, 2004 | 04:43 AM
  #123
GDB's Avatar
GDB
Originally Posted by yoyoyoyoming
very disappionted about the FQ400 after watched the vid ............it's more like a track car ............ not a car u can drive in cities(i feel like i can't do anythings w/ this car) ......... (fast don't really mean nothing)......lambo is better ........
With all due respect sir, a Lambo isn't exactly a car that "you can drive in the cities".
It has a bad turning radius, maybe as bad as Evo; is very wide thus making maneuvering in tight spaces (such as parking lots) a challenge; it doesn't have meanigful boot space; has a rather poor ground clearance...
... AND LAST BUT NOT LEAST, TRY PARALLEL PARKING A LAMBO.
FQ400 isn't an IDEAL city/daily driver, I agree. That's why FQ320/340 was recommended.
Old Dec 27, 2004 | 09:07 AM
  #124
machron1's Avatar
Ummmmmm The EVO itself is a track oriented car. It's simply not a plush comfy ride. The FQ400 just pushes it a little more toward track than daily driving, and even then only because it has a double plate clutch. I doubt they have broadened the turning radius of the FQ400 over the base model Evo, so I don't see that as a negative. I also believe it has the same Bilsteins as the normal MR, so it is probably more comfy around town that most people's Evos. I also really doubt the dual ball bearing turbo has significantly more lag than the stock turbo. That 6th gear pull from 30mph just demonstrates how the Evo doesn't do that well in the wrong gear, but it's more of a function of a 2.0L motor with 8.8:1 compression trying to do a top gear pull @ less than 1,500 rpm. It's ludicrous to think someone wouldn't downshift in that situation, or would even think 6th gear was the proper gear at all.
Basically, other than having to rev it a little more from a stop, I doubt it's really the pain in the *** they tried to portray it as.
Old Jan 22, 2005 | 01:13 PM
  #125
Jakeg97's Avatar
Originally Posted by DoggieHowser
It isn't my website... I was redirected there by a friend who got it from another friend etc..
Anyway, found out you can *ahem* maybe bypass the registration process...
http://www.evolutionfq.com/subd/plug...00-Topgear.wmv
not
Old Jan 22, 2005 | 01:22 PM
  #126
Jakeg97's Avatar
Originally Posted by justchil
If you don't want the hassle of registering... I'll try to get the full 700mb version too!
http://justchil.net/dl/vids/FQ400-Topgear.wmv
If u get bored click my advertisement on the main page
not found
Old Jan 22, 2005 | 01:25 PM
  #127
Jakeg97's Avatar
For those who want to download it...
http://www.evolutionfq.com/subd/inde...13_sectionid=3
Need to register as a member tho..
dont want to register
Old Jan 22, 2005 | 01:27 PM
  #128
Jakeg97's Avatar
Originally Posted by evoWALO
The whole episode (700MB HighRes) can be downloaded off suprnova.org
http://66.90.75.92/suprnova//torrent...tv-avi.torrent
doesnt work
Old Jan 22, 2005 | 01:29 PM
  #129
Jakeg97's Avatar
grrr
Old Jan 22, 2005 | 07:11 PM
  #130
Jakeg97's Avatar
Originally Posted by rebelzx
http://www.layeredchaos.com/CSi/FQ400-Topgear.wmv
Use this link for now, if it goes down I will rehost.
finally a link that works !
cb169
Mar 29, 2017 11:27 AM
5LEEPERISAH23I
Nov 2, 2010 08:39 PM
MasterAK
Lancer Engine Tech
Feb 8, 2008 11:02 AM
sccavee
18
Aug 2, 2005 07:21 PM
DjDoubt
May 2, 2005 10:49 PM
