where can i get a water temp t-fitting for upper radiator pipe?
Originally Posted by Matz
But your solution is cheaper, and we can get it today!
- Steve
Originally Posted by SuperHatch
No doubt, but I for one like "clean" installs. This adaptor will allow me to make the install look OEM.
- Steve
- Steve
Well, I'll see if 42DD has any info / prototype pictures on their site.
True... and with the amount of money we spend on our Evos, what's $50, right?
Well, I'll see if 42DD has any info / prototype pictures on their site.- Steve
Are you back yet?
I'd like to try your approach, as it seems that my GReddy adapter order hasn't even shipped yet, and I'd really like to get another sensor installed...
Thanks!
Thanks!
it's kinda hard to take a good picture, but it's really pretty simple, just brass fittings.
Originally Posted by WarmPepsi
sorry, landed just after midnight, got home at 4am, and a bit tired
Thanks for the pics! Looks really good!
Originally Posted by BADEVO
Any idea what size T you used WP ?????
but not sure of what size the hose fittings were (the nipples that go inside the stock rubber pipe.
You also need your temp sender unit, so you take it all down to advance, or napa, and get the whole setup done in one.
So if 42DD were to offer the thermostat housing w/ a bung welded on, they would have to sell the part I circled. That part itself costs $55 from mitsubishiparts.net.
If you place a bung on the elbow after the thermostat, it'll still read the same as the upper radiator hose.
It's probably easiest to just tap the turbo water line for the temp reading.
The temp sensor is on the hot side of the thermostat.... right where it should be.
- Steve
- Steve
Ok, having said that and looking at 42 designs housing isnt the sender port on the wrong side of the thermostat?
https://www.evolutionm.net/forums/sh...d.php?t=177687
looks like it's not any different than tapping into the hose after the radiator... but maybe this product is aimed towards making people's lives easier, and not necessarily to get the most accurate coolant reading.
Originally Posted by marksae
I do like that a lot better than tapping the upper radiator hose. It looks a lot cleaner. I'll get this eventually to clean up the engine bay.
