getting "shocked"!!!!!!
Old Jan 6, 2005 | 12:32 AM
  #31
mvm42699's Avatar
From: 85296, 99519, 96817,98310,07306,10461(HomeSweetHome), & 00739
Install a DIY interior grounding kit or wear an anti static wrist strap....
Old Jan 6, 2005 | 01:08 AM
  #32
mrmefodman's Avatar
hyperground cables
LOL
Old Jan 6, 2005 | 01:52 AM
  #33
EVO_JOE's Avatar
Originally Posted by silvrevo
Is there somthing that your can spray on the seats and the carpet so when you get out of the car you dont get a SHOCK, everytime you go to shut the door? Im sick of this
Thanks
this is what you need
Let me know if you want it I can order it for you
Old Jan 6, 2005 | 08:13 AM
  #34
Cirrusly Evolvd's Avatar
You are getting shocked because your car is creating the static field as it travels down the road. Yes, even rubber tires will create a static charge just like when you scuff your tennis shoes on carpet and then touch metal. When you exit the car and touch the metal surface you are creating a low resistance ground for that charge to dissipate through. Easiest solution is to touch the metal part of the door before you put your feet on the ground. Or you can buy a grounding strap that hangs below your car. They most certainly work, we use them on military aircraft so that sensitive electronics aren't destroyed by static build up.
Old Jan 6, 2005 | 09:48 AM
  #35
silverghost's Avatar
Thumbs up shocking solution
Use Static Guard or Cling Free both available at the grocery strore. I tried it and it works. Just spray the seats lightly. Each spraying lasts 4-6 weeks before you wear too much off for it to still be effective.
Old Jan 6, 2005 | 12:50 PM
  #36
silvrevo's Avatar
maybe it wont hurt so much if I try not to close the door with my Privates,,,,,lol
I do have the grounding kit and it dosnt help...... Im going to try the Static cling stuff.....or maybe even some scotch gaurd???????
Old Jan 6, 2005 | 12:54 PM
  #37
plokivos's Avatar
just do your laundry with static free stuff.
that or just take it like a man, you sissies.
Hiboost
Jun 21, 2014 08:31 AM
SilentCool
Jan 29, 2014 09:08 PM
rage mang
Jun 24, 2013 02:33 PM
yitzac1990
Aug 13, 2010 09:32 AM
dan00780
14
Dec 6, 2005 08:33 AM
