Mitsubishi car problems
Old Dec 30, 2002 | 08:18 PM
jigglyp83's Avatar
Registered User
Hey im about to buy a Evo 8 and i was wondering about the belt of the mitsubishi keep on snapping off, b/c i heard alot of the mitsubishi car and there problems with their belts snaping and alway buying a new one. WIll this happen to a EVO LANCER???!?!??! plz answer me b4 i buy one =P thanks
Old Dec 30, 2002 | 08:21 PM
evo_dan's Avatar
Re: Mitsubishi car problems
If I understand it correctly, even if the timing belt snaps I don't think the pistons touch the valves, which would mean no problem. Can someone second that for me?
Old Dec 30, 2002 | 08:22 PM
jigglyp83's Avatar
Registered User
yes the timing belt? haha oops yea i alway here about these problem that mitsu alway has
Old Dec 31, 2002 | 06:48 AM
Mark F's Avatar
My desk is right next to the service department customer lounge. I've never seen or spoken with a single customer who had a timing belt failure in the 20 months I've been at this store.
Old Dec 31, 2002 | 08:09 AM
GPTourer's Avatar
Mitsubishis use interference heads. If the timing belt snaps (your supposed to change it every 60,000 miles) you will most likely bend some valves and ruin a piston or two. A new engine will most likely be needed. This isn't a "Mitsubishi problem" it is common in a lot of small high performance motors. Some Nissans and Toyotas are the same way.
Old Dec 31, 2002 | 08:10 AM
evomk8's Avatar
I think the problem you're referring to is mainly limited to the 3.0l 6G72 V6 found on the older Diamante (pre 1997) and older Montero. As far as I am aware, this has been fixed. The current Galant, Eclipse and Montero Sport use this engine and do not have this problem (again based on my limited knowledge on this).
Old Dec 31, 2002 | 08:15 AM
TearItUpSports's Avatar
The 4G63 is an interference engine, which means if the timing belt goes, so will the engine. It is just one of those things you should change before the manual says, about every 40k miles.
I had to replace the engine in my galant, because the previous owner didnt have the tensioner correct and my cam jumped a few teeth. It was really my fault for not checking though.
This is not a big deal as long as you dont forget about it for 80k miles or so.
Old Dec 31, 2002 | 09:01 AM
Jonasan50's Avatar
Timing belt break, engine break.. Service your car, engine not break.. Simple as that... If serviced properly and in the allotted time, the car will be very reliable... Trust me, I pretty much drive very hard all the time (it's just so much fun), but I always take care of it at the same time.. So it'll be fine...
Old Dec 31, 2002 | 09:26 AM
sblvro's Avatar
the 6g72 engines are non-interference, so if the timing belt breaks, it will not damage the valves or pistons. the new ones like 6g74 are interference engines. the old diamante's are non-interference, and the problem were not valves hitting the piston but defective oil seals that promoted engine oil going past the valves and seals.
Old Dec 31, 2002 | 09:27 AM
sblvro's Avatar
my point exactly!
Old Dec 31, 2002 | 10:33 AM
jigglyp83's Avatar
Registered User
Thanks guy thats good info i just need
eddy5201314
Oct 19, 2016 04:50 PM
mekis13
Sep 12, 2016 11:44 PM
evo_k
Pacific Northwest
18
Jan 10, 2015 07:56 PM
