Toasted ACT Clutch disc? or not
Old Jan 22, 2005 | 10:58 PM
RalliArtEvoVIII's Avatar
My TC has the worn out bearings issue. So i dont wanna risk dumping the clutch at high RPMs, so i raced my friends 240 with a sr20det swap. I did a 5k rpm quick slip but still burnt my 2 month old ACT HDSS clutch. During the race i could smell it STRONG. I let it cool off for a while and let it sit overnight, woke up drove it about 50mi, and smelled the bay and i smelled it still but wasnt as strong. Its been 3 days and i dont smell it anymore. HOw bad could the damage be? I know the clutch is ceramic so i know it can withstand high heat, but..?
LoOk kAKa (10:57:50 PM): i thought that was it
Old Jan 22, 2005 | 11:03 PM
naucrx's Avatar
Ouch! That sounds like the first time I burnt my stock EVO clutch. I smelled it for about 2 days. But it lasted me 40k.
Old Jan 22, 2005 | 11:24 PM
evo81's Avatar
that was just a bad slip.its hard to tell how bad it was without taking it out to look at it.
Old Jan 22, 2005 | 11:40 PM
well it drives like normal. No slippage or anything
Old Jan 23, 2005 | 12:16 AM
mrmefodman's Avatar
just know u have x amount of bad smells till its destroyed.. be careful
Old Jan 23, 2005 | 12:20 AM
plokivos's Avatar
i fried my act clutch on half slip at 6000 rpm (didn't disengaged fully due to master cylinder adjustment). everything is good, didn't even smell anything.
you shouldn't quick slip with your clutch, you should long slip. it'll be safer.
i don't smell my clutch at all when i launch now. But I don't do the 5000 rpm slip, i do 3500 rpm, works just as well.
Old Jan 23, 2005 | 12:23 AM
mrmefodman's Avatar
Old Jan 23, 2005 | 12:26 AM
plokivos's Avatar
30 = x ?
i think thats about right for the stockers.
Old Jan 23, 2005 | 08:30 AM
sleet's Avatar
Is the ACT HDSS clutch the same as their street one?
Old Jan 23, 2005 | 08:11 PM
ACTman's Avatar
It's not ceramic if you have the HDSS. The street disc (any street type disc) uses a resin that binds the friction material together. Overheat the clutch and the resin melts, and becomes more like a lubricant (so it will slip even worse) and will stink really bad. The ceramic will not smell near as bad or not at all.
Old Jan 23, 2005 | 08:15 PM
lil'evil_evo's Avatar
but very true. I hate that f uckin smell
Old Jan 23, 2005 | 08:17 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
i did the same thing....don't slip it a lot and it will be fine.
DAve
Egal44ARock
Jun 24, 2015 09:30 AM
Metal
13
Jul 2, 2013 08:06 AM
ToddMcF2002
Mar 16, 2010 01:26 AM
DSMEVOLUTION
Nov 21, 2007 07:24 AM
plokivos
63
Mar 17, 2005 09:14 AM
