Tar/Grav/Snow Simultaneous Lights!
Old Jan 25, 2005 | 12:16 PM
Waz996's Avatar
Greetings,
Today i was pushing the car to its steering limits *which i usually do occasionally* and later i found out the Tarmac/Gravel/Snow Lights are lit simultaneously!!! Press the AYC button would not affect..
Is this some kind of sign, code or warning?
I immediately parked on the side, turned engine off and on, and everything back to normal..
Comments appreciated..
Thanks
Wae *Heeeelp!!*l
Evo7
Old Jan 25, 2005 | 12:24 PM
donour's Avatar
I believe that indicates a problem with the ACD system. Check the owners manual.
d
Old Jan 25, 2005 | 12:30 PM
Waz996's Avatar
Car is jap import.. the manual is in jap..
Anyone has idea on what to do pls help..
Wael
Old Jan 25, 2005 | 12:39 PM
Jamdown's Avatar
steering limits? I hope it doesn't mean donuts . I hope someone with an 05 can help, but I hope its nothing big
Old Jan 25, 2005 | 12:45 PM
omniphil's Avatar
All 3 lights on indicate a ACD system fault. Its in the English manual
Old Jan 25, 2005 | 02:41 PM
gunzo's Avatar
ACD detected fault and flags a fault by displaying all 3 codes ..
if after restart everything is okay .. you're okay .. temporary fault..
alot of things causes the lights to be on .. and most common usually is lack of fluid .. or starvation ..
Old Jan 25, 2005 | 08:23 PM
Waz996's Avatar
Gunzo, u're the man!
Thanks everyone, I just noticed a small leak from the tranny and will go solve it now.. It must be from the clutch change process..
Thanks again,
Wael
Old Jan 26, 2005 | 04:57 AM
gunzo's Avatar
make sure the guys who changed your clutch bleed the ACD thoroughly ..
mda56
Dec 12, 2015 12:12 PM
gizmotoy
Apr 9, 2015 06:33 AM
Roger350
Mitsubishi TC-SST Discussion
Jul 18, 2013 09:54 AM
RxRA
10
Nov 25, 2012 10:21 AM
2009GRAYGTS
Mar 31, 2010 05:50 AM
