xede flash vs dynoflash
Old Jan 27, 2005 | 07:12 AM
alby988's Avatar
Which one is considered better? Which one has less issues, I'd rather take the one with less issues even if it has less gain. Please leave feeback thanks
Old Jan 27, 2005 | 07:16 AM
jason@NTEC's Avatar
they are all tuned by the same software so just go with the one your more comfortable with. x-flash, turbotrix flash, dynoflash, and works all make a great product. with the exception of the works p2 which controls boost itself and doesnt require a mbc, they are all pretty much the same. do the research and see which you like best and go with it.
Old Jan 27, 2005 | 07:20 AM
DarrenJ's Avatar
With any of the flashes, do you have to worry about boost peaks triggering a cel. I'm not planning to get a boost gauge, and I wanted to know if any flashes would run into this problem
Old Jan 27, 2005 | 07:26 AM
UFO's Avatar
UFO
DynoFlash customers will tell you to DynoFlash is better.
Vishnu customers will tell you Vishnu is better.
As for boost gauge: Just buy one. You don't need to worry about boost spikes with most of the flashes but the Works flash might be a different story.
Old Jan 27, 2005 | 07:28 AM
Event-Horizon's Avatar
The best thing you can do it to go to each of their forums under the "vendor forums" section and read up on each. This topic is highly debated and can lead to a flame fest. Both are great products and using one or the other depends on what you want to do with the car.
The XEDE is a piggyback that uses the signals from the stock ECU to change fuel, timing, etc. It also controls boost so that you do not need a separate boost controller. The XEDE is great for “do-it-your-self” type crowd allowing you to tune your own car (hopefully on a dyno ) You can also download more maps from the Vishnu website if you upgrade your car. I think a XEDE is great for those that upgrade their car more frequently. You can also store two maps in the XEDE. For example, one map may be your daily pump gas map and the other map could be used for race gas and higher boost levels.
The dynoflash is also another great product. You can get several different tunes from them depending on your bank account. I tend to think that dynoflash is good for those that do not have easy access to a dyno and would like to get another 20-30whp (or more depending on mods) out of their car. Al can also tune out the lumpy idle from cams if you do not like the lope that cams give. I’m not sure if this is still done, but I think dynoflash has the ability to store a second map on the ECU also. I have seen some very good results from Dynoflash in drag racing.
Hope this helps, and check out the vendor forums here:
https://www.evolutionm.net/forums/vendor-forums-73/
Read a little too quick...just saw that it was about Xflash and not the XEDE :P
Old Jan 27, 2005 | 07:29 AM
EidolaDream's Avatar
looking at my sig would give away which I would pick, just a big fan of shiv and vishnu they make killer products and the car still has a stock feel to it. I cant give a good answer to you man with out being partial to vishnu.
I honestly dont know what each company is changing for there flashes so you may consider calling each company and asking which is better and why..
Old Jan 27, 2005 | 12:03 PM
evo81's Avatar
DYNOFLASH 4 LIFE ...... until i get an aem ems
Old Jan 27, 2005 | 03:04 PM
Alias's Avatar
I suggest you do a search and learn about it as much as you can and then decide for yourself. Let's not try to start anything again.
Old Jan 27, 2005 | 03:23 PM
WildRice's Avatar
The Xedeflash is a supplement to the Xede which is a user adustable interface (piggy back). The Dyno flash is complete in and of itself and can be as customized or "off the shelf" as the applicaton and customer warrants it to be. Which is best is highly subjective and depends largely on the end users skills and objectives.
ruarctb
Lancer Troubleshooting
11
Apr 12, 2016 10:59 AM
CeeWhizzle
12
Dec 22, 2015 09:09 AM
w8less1der
13
Mar 5, 2015 05:06 AM
Johns_EVO_IX_SE
Jan 7, 2014 05:09 PM
