Motor Trend states the Center diff is 50/50. Is that the "Tarmac" split on ACD?
Motor Trend states the Center diff is 50/50 for our US Evo. Is that the "Tarmac" split on the ACD in Japanese spec Evos? Better yet does anyone know how the power is divided between Tarmac, Snow and Gravel on the acd?
First of all, Tarmac setting on the ACD equipped cars is not set to any specific ratio. It is an active setup that changes while you drive the car. In the most simplistic way, it gets less locked when you are turning (steering wheel sensor) and more locked for the straight line acceleration and braking.
Now 50/50 split would be more like the Snow setting on the ACD, but even that one gets to see an open diff sometimes (just not as much and not as long as the Tarmac option).
For the LSD with the viscous coupler, split is really never 50/50. The slip exist all the time and when more slip occurs (meaning, higher speed difference between the two sides), more locking happens at the same time. After the more locking happens, wheels decrease the difference between them and locking force goes down and let them to be more free.
So, from this said, if the diff (actually the viscous coupler) is more tight, car will be more like the Snow mode and closer to the 50/50 most of the time.
The more loose diff will stay more opened and closer to the Tarmac setting, it will corner better, but might leave some time accelerating in the straight line due to excessive tire spin.
Hope this helps!
Fedja
Hope this helps!
Fedja
50/50 gives you the best of the AWD traction world. Too much in the front, and you get some serious push in the corners. Too much in the rear (most exotic AWD cars are 20/80 split) and too much oversteer in the corner.
Fedja
I am very afraid EVO with machanical central LSD and open front diff. will have a lot more understeer then JDM one. Subaru claims it used front SureTrac LSD to cut understeer so in USA EVO/STi character might be reversed from EVO VII/STi7 JDM.
I hope I am wrong on this one.
actually an open diff in the front will more closely resemble a rwd car. lsd with clutches for the front will give you too much understeer and will give the best straight forward traction. If you simply throw a mechanical lsd (torsen type) in the front you may have too compensate with a bigger sway bar in the rear too give better rotation. Me personally will never use a clutch type lsd in the front (cuzco), but would consider a torsen-type. A viscous center diff will provide a good balance of torque between front and rear. The reason EVO 7 had a lsd front diff and worked great was because it also had AYC to compensate for rotation making a bigger sway bar not necessary.
Hope your hopes are right and that you are wrong too!!
Fedja
I tend to dissagree here. Usually the best setups were AWD with a rear bias (check Skyline).
From http://www.impreza.subaru.com/micros...sti/wrxsti.jsp
Now about Suretrac from a different source
So it does not use clutches.
A torque sensing LSD is essential at front not to work under braking. And how enhancing traction at front can cause understeer? It's just opposite in my book.
My hopes are based on the whole car setup making it less understeering pig but open fron diff is definately a bad thing and adds understeer.
And if Skyline is a bad example please give me a better one.
Impreza WRX STi employs a new Suretrac® limited-slip front differential and a mechanical limited-slip rear differential. The Suretrac differential is a gearless unit that responds to a torque differential between left and right wheels to increase traction and reduce understeer.
Suretrac utilizes an arrangement of opposing cams and followers which enables the device to transmit whatever unequil torque the tire contacts can withstand, upto a torque limiting ratio set by the design
So, by just saying it plain like that about the open front diff and understeer, is not completely correct! Of course, since they where talking about the understeer they had to be turning, so this doesn't really work like that. For the straight line, it is a great help!
Fedja
Originally posted by Jonasan50
I believe it would be the same as tarmac... The Eclipse GSX is split the same way.. Not a bad way to go... Much fun.....
Originally posted by MrAWD
From the cornering perspective, outside wheel is trying (or you are trying to make it to do so) to get as much traction as it can, and speaking in the traction circle terms, to get as close and as long as possible to the 1 (one).
911, EVO 1-3, STi with DCCD,...
911 Turbo has from 5% to 40% torque sent to front wheels.
I have no idea about EVOs but feel free to fill me in.
And open diff transferring torque to the other wheel which is unloaded and looses traction earlier helps?
The thing is that all of the power that goes to the inside wheel gets kind of wasted, but even that is better then send it to the wheel that is already at maximum cornering limits and has nothing else to use for the acceleration.
STi with DCCD has 35/65.
Fedja
