All Part Number Request Go Here
Old Sep 28, 2004 | 09:23 AM
  #136
marksae's Avatar
Bump for the OE tranny fluid p/n.
Old Sep 28, 2004 | 10:19 AM
  #137
JustDSM's Avatar
Mark,
As I stated previously.. I'm far, far away.. My contact is a Tech at North Point Mitsubishi in San Antionio. I would have him get it for me. However the guys in the service dept. there are generally pretty cool cats. Give them a call and tell them you need the part number for the Mitsubishi Diamond gear old (for the EVO) thats in the 5 gallon drum.
If they don't help you out let me know and I'll give them a ring when I can.
Their number is: 210-249-7501
Old Sep 28, 2004 | 11:56 AM
  #138
marksae's Avatar
Originally Posted by JustDSM
Mark,
Cool.. thanks for the contact info! I was just wondering if there were any options other than getting the 5 gallon drum.
Old Sep 28, 2004 | 02:17 PM
  #139
os2's Avatar
os2
Please!
some common
- transmission drain plug gasket
- trasmission fill plug gasket
- transfer case drain plug gasket
- transfer case fill plug gasket
- rear diff. drain plug gasket
- rear diff. fill plug gasket
and less common
- headlight height adjustment switch (with 4 position dialer on a lower left side of a dash, next to dimmer rheostat)
- 3rd stoplight cover
Old Sep 28, 2004 | 06:15 PM
  #140
JustDSM's Avatar
Not to my knowledge.
Old Sep 29, 2004 | 11:39 AM
  #141
Audio18's Avatar
Several times people have posted on this thread that they needed the silver console cover that goes around the shifter, ash tray, and 12v. Each time, the part MR633547 was given. Later someone asked for the black bottom of the console that supports the trim panel, and part MR647677 was given.
I recently ordered MR633547 expecting the trim panel. Instead I was sent the bottom part of the console. Could someone please verify that the correct part number is for the upper silver trim panel for an Evo?
I called the dealer, and they clain MR647677 is the part # for the trim panel.
Old Sep 30, 2004 | 12:12 PM
  #142
JustDSM's Avatar
Are you refering to this post?
https://www.evolutionm.net/forums/ne...eply&p=1128471
I'm looking at CAPS right now and the lower portion of the console is MR633547 and the upper is MR647677
Not doubting you.. But this is odd.. Can you reverify the part number on the box? Also, when you ordered it, did you order by description or by the PN# listed here (or somewhere else..)?
If I could, I'd include a screen shot of caps indicating those are infact the correct part numbers.
Get back with me..
[EDIT]If you go to the parts dept have them go to Main 52, Sub 080 and show you PNC 74041. Thats MR633547 (the lower part of the center console). Then have them show you PNC 24054. Thats MR647677 (the upper portion.
Old Oct 7, 2004 | 11:08 AM
  #143
os2's Avatar
os2
Could you please look up these part numbers in CAPS, thanks!
Originally Posted by os2
Please!
some common
and less common
Old Oct 7, 2004 | 03:32 PM
  #144
Audio18's Avatar
Thanks Justin, I appreciate you verifying that part number for the upper console trim piece. I wish I had double checked this before ordering the first time!!
Old Oct 7, 2004 | 09:22 PM
  #145
JustDSM's Avatar
Please!
some common
- transmission drain plug gasket MD000312 (CAPS is a little vauge on this, but this should be it)
- trasmission fill plug gasket MF660036
- transfer case drain plug gasket MD000312
- transfer case fill plug gasket MD000312 (Again, CAPS being vauge, this should be it)
- rear diff. drain plug gasket MB001294
- rear diff. fill plug gasket MF660036
and less common
- headlight height adjustment switch (with 4 position dialer on a lower left side of a dash, next to dimmer rheostat) MR506482
- 3rd stoplight cover MN126920HB (You have to get the whole light assy.)
All parts and notes above in bold.
Old Oct 8, 2004 | 06:51 AM
  #146
os2's Avatar
os2
Thanks a lot Justin
Old Oct 8, 2004 | 07:43 AM
  #147
marksae's Avatar
P/N request for the 05 teflon shifter cables. I'm not sure if they're only available on the MR or whether they're used across the board on all 05 EVOs and lancers.
Old Oct 8, 2004 | 07:57 AM
  #148
JustDSM's Avatar
The MR has a different part number than the GSR and RS models. All GSR and RS models ('03-'05) have the same shift cables.
MR: MR580533
GSR/RS: MN107670
Old Oct 8, 2004 | 12:20 PM
  #149
marksae's Avatar
Thanks Justin! The MR shifter cable is $91 from mitsubishiparts.net. Is that part number for both cables together?
Old Oct 8, 2004 | 01:58 PM
  #150
JustDSM's Avatar
Yes sir!
