All Part Number Request Go Here
Old Mar 14, 2007 | 06:57 AM
  #1681
spln*up's Avatar
yes the 2 bars underneath the car, the ones that almost touch my 3"downpipe.
Old Mar 14, 2007 | 07:14 AM
  #1682
Rich@Orbital's Avatar
Originally Posted by Spins4
Left: 5716A169HA
Right: 5716A170HA
And so you know, the fronts and the rears are the same. Hope this helps Rich!
Thanks Bill!
Old Mar 14, 2007 | 07:29 AM
  #1683
Spins4's Avatar
The bolts are MS240295, which go for $1.32 eac..and I see no spacers....
Old Mar 14, 2007 | 07:31 AM
  #1684
Spins4's Avatar
Originally Posted by Rich@Orbital
Thanks Bill!
Anytime!
Old Mar 14, 2007 | 03:25 PM
  #1685
psphinx81's Avatar
evo 9 front bumper
part #?
Old Mar 15, 2007 | 07:44 AM
  #1686
Spins4's Avatar
Originally Posted by psphinx81
evo 9 front bumper
part #?
6400B002WA
Old Mar 16, 2007 | 06:35 AM
  #1687
cfdfireman1's Avatar
03 EVO-Roll pin that holds the master cylinder reservoir to the bottom. The nail I replaced it with is starting to rust.
MR244930
Bill,
Ship it please.
Old Mar 16, 2007 | 06:39 AM
  #1688
justchil's Avatar
Looking for the c-clamp/clip that holds the throttle body shaft in place. 2003
Old Mar 16, 2007 | 10:31 AM
  #1689
Spins4's Avatar
MR244930
Old Mar 16, 2007 | 10:33 AM
  #1690
Spins4's Avatar
Not available seperate....
Old Mar 16, 2007 | 12:41 PM
  #1691
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
In the stering column, left hand side, a semi-circular sensor (black and can see the copper) in which the ignition harness plugs into. You would connect a TT harness there as well. There is a white semi-circular part attached which slides in-place (on the other side of that is where you insert your key) Held in-place by a screw. I think it's refred to as the key or ignition cylinder. Thanks!
step #5 is a picture of it.
http://evomoto.com/tech_info.php?tPa...6474354cbd268d
Old Mar 18, 2007 | 06:14 PM
  #1692
sonicnofadz's Avatar
Bill, could you give me the prices for:
MD372536 cam seals
I also have two mystery items I need part #'s and prices for:
The rear bolt for the front cross-member:
Along the radiator core support in the front of the car, there is a section of wiring harness that is clipped down by plastic zip tie looking plastic thingies. I need six of them. Thanks!!!
Old Mar 19, 2007 | 10:49 AM
  #1693
SLVRNBLK's Avatar
I really need help getting the part number to part IM describing in post #1691.
I accidently broke mine, and now I cant start the car without it.
Old Mar 19, 2007 | 01:30 PM
  #1694
Spins4's Avatar
MR244930
Bill,
Ship it please.
Just give me a call at the number and my sig, and I'll gladly help you out. Thanks!
Old Mar 19, 2007 | 01:32 PM
  #1695
Spins4's Avatar
Kind of lost on this one, which piece exactly you need? If you have access to fax, I will more than gladly send you a pic from CAPS and could take it from there?
