All Part Number Request Go Here
Old May 3, 2007 | 09:30 AM
  #1816
yikez's Avatar
Request part number for an 'output shaft' and 'C' rings around the shaft. This is the shaft between the t-case and transmission.
this is for an evo ix ACD t-case ..
Thanks!
Old May 4, 2007 | 12:43 PM
  #1817
whitersevo's Avatar
hmmm cant seem to find it???? but I am looking for the Hydro. valve lifters part number!!!
Old May 9, 2007 | 03:45 AM
  #1818
michaels_evo8's Avatar
Part number request if anyone can help me with this.. the bolt and clamp that is front center of the valve cover that holds the thottle cable in place. Thank you!
Old May 11, 2007 | 10:34 AM
  #1819
Spins4's Avatar
Bolt is MF243624, and the bracket thing is MN100121
Old May 11, 2007 | 11:52 AM
  #1820
yikez's Avatar
any part no. for this?
part number for an 'output shaft' and 'C' rings around the shaft (they may come together not sure). This is the shaft between the t-case and axle
thanks
Old May 13, 2007 | 12:20 PM
  #1821
mcwop23's Avatar
and evo IX passenger side headlight assembly please
Old May 17, 2007 | 06:54 AM
  #1822
heyzeus11's Avatar
Is there a part number for the metal clip that holds the end of the connector/plug that connects/plugs to the TPS sensor? Shaped kind of like a " C " (I know not the best description). It appears this part is used on several of the sensors on the car as well.
Old May 17, 2007 | 08:01 PM
  #1823
04EVO's Avatar
I need the coil boots. I already have the cable set, I need the boots that go under the coils.
Old May 18, 2007 | 02:09 AM
  #1824
EvilBlueEvo8's Avatar
Question. Anyone know what the glove box lock MR633552 is for? Is it a replace handle with a lock for the glove box? Would it use the ignition key I already have or would it require an additional key? Any pics? It was listed on mitsubishiparts.net as an interior accessory for an 05 evo. Will it fit any evo (including my 03)?
Old May 18, 2007 | 02:02 PM
  #1825
qnz's Avatar
qnz
i need the part number for the 2 bolts that hold the caliper to brake assembly. thanks
Old May 18, 2007 | 02:09 PM
  #1826
evolved8's Avatar
boots are md623072 list = 40.32 each
Old May 18, 2007 | 03:37 PM
  #1827
04EVO's Avatar
I looked that up and I came up with the ignition coil it self?...
Old May 21, 2007 | 04:39 AM
  #1828
evolved8's Avatar
well, then the only other part number it can be is 1832a033
Old May 21, 2007 | 09:00 AM
  #1829
anyone?
Old May 21, 2007 | 10:15 AM
  #1830
rallykid's Avatar
double din radio bezel
I would love to get a part number for the double din metallic radio bezel that comes on JDM Evos.
Can you guys help?
