All Part Number Request Go Here
Old Apr 24, 2007 | 10:02 AM
  #1801
Spins4's Avatar
Originally Posted by MTRJunior
how much would those 3 pieces be shipped to 06811?
$95 shipped/insure w/ tracking...
Old Apr 25, 2007 | 04:35 AM
  #1802
suprahom's Avatar
Hi Bill,
I've got one question rather than a request for part number. Are these part numbers interchangeable or exclusive?
Steering wheel : MN100378XB
Pass side airbag : MN185260
Steering wheel: MN100378ZZ
Pass side airbag: MR951403
Old Apr 25, 2007 | 06:30 AM
  #1803
Spins4's Avatar
Originally Posted by suprahom
Hi Bill,
Well, the steering wheel part numbers I have are the MN100378XB (which you have), which is the newer all black steering wheel. Now the other number I have is the same, but ends in "XA" rather, and that would be the more silver steering wheel.
As for your airbag numbers, the MN185260, all CAPS tells me is that it is an "air pyro type", and the other number is "gas".
Old Apr 26, 2007 | 05:57 AM
  #1804
Jim in Tucson's Avatar
As I understand it, here are the parts needed to install an IX turbo into an VIII:
Quantity Part # Description
1 - 1515A057 Fitting, Air Output
1 - MR281085 Gasket, Air Output
1 - 1310A171 Pipe, Water Return
1 - 1310A248 Pipe, Water Feed
1 - 1225A042 Tube, Oil Feed
2 - MF660063 crush washer
2 - MF660064 crush washer
4 - MF660065 crush washer
What I'm missing is the gasket PN for the oil return tube on the bottom of the turbo... appreciate the help.
If any Mitsu parts people are monitoring this thread, please quote me a price for all the above shipped to 85704.
Thanks,
Jim
Old Apr 26, 2007 | 07:55 AM
  #1805
Spins4's Avatar
Thanks,
Jim
Your numbers are correct, if you look here, https://www.evolutionm.net/forums/sh...d.php?t=231811 , 4th item down
You are just missing the MN156738, which is an additional $1.34.
Shipping run you around $10, and if ordered today, I could have it shipped tom.
Old Apr 26, 2007 | 10:18 PM
  #1806
Thanks, Bill.
I guess I was unclear. I do need the entire turbo install kit. I'll give you a call.
Jim
Old Apr 27, 2007 | 09:33 PM
  #1807
Knightracer's Avatar
Anyone have the part # for the evo dipstick? thanks
Old Apr 28, 2007 | 12:42 AM
  #1808
LanEvoBL155's Avatar
can i please get the part number for a evo 8, 2003 throttle position sensor? thanks in advance!
Old Apr 28, 2007 | 06:28 AM
  #1809
Spins4's Avatar
MD343884
Old Apr 28, 2007 | 06:35 AM
  #1810
Spins4's Avatar
MD628074
Old Apr 29, 2007 | 01:42 AM
  #1811
MD628074
thanks a lot!
Old May 2, 2007 | 09:41 AM
  #1812
LostSolVTEC's Avatar
is the cam position sensor on the evo 9 the same as the evo 8??
Old May 3, 2007 | 04:06 AM
  #1813
marksae's Avatar
Request for front wheel bearing part number.
TIA!
Old May 3, 2007 | 06:19 AM
  #1814
Spins4's Avatar
Yup!
Old May 3, 2007 | 06:20 AM
  #1815
Spins4's Avatar
TIA!
MB914617 , it actually comes as a whole hub assembly.
