All Part Number Request Go Here
Need vacume lines
Someone please help me i need the stock vacume lines that run from the turbo to wastegate and back around up to the boost solonoid and i need the vacume line that runs from the boost solonoid to the intake. The hose line for the blow off valve. Last i need the vacume line that is on the intake manifold, when you open your hood it is all the way in the back left(usually what you tap into for boost gauge).Please someone sell me these if you have put on a boost controller in need of parts soon.
mine keyless entry and engine immobilizer- if there isn't any shock sensors available i'll probly just go aftermarket- just by looking at the pics of the guys here whose cars got trashed makes me want to have it installed right away, at least some form of deterrent
Originally Posted by blakevo8
Someone please help me i need the stock vacume lines that run from the turbo to wastegate and back around up to the boost solonoid and i need the vacume line that runs from the boost solonoid to the intake. MB143555
The hose line for the blow off valve.MN143343 (This includes the metal portion as well)
Last i need the vacume line that is on the intake manifold, when you open your hood it is all the way in the back left(usually what you tap into for boost gauge).Please someone sell me these if you have put on a boost controller in need of parts soon. I need to know which of those hoses you need. Is it from the manifold to the FPR solenoid or FPR solenoid to the regulator?
****Note**** I corrected a typo for the first P/N listed in this post.
Ok i know exackly what i need now, i need the bolts that are used for the turbo 02 housing cover. Next i need the upper IC piping clamps there is 2 of them. Next i need the 4 bolts that hold on the Mass Airflow sensor to the airbox. Last i need this vacume line shown in the picture. It is from the turbo wastegate actuator to the turbo wastegate solonoid.(it goes into the "T" it is marked with red.
Please help i really need these parts.
Ok i know exackly what i need now, i need the bolts that are used for the turbo 02 housing cover. The heat shield I assume? Here is the P/N for those: MR385780
Next i need the upper IC piping clamps there is 2 of them. Best bet is to get this at your autoparts store. They're likely to be cheaper
Next i need the 4 bolts that hold on the Mass Airflow sensor to the airbox. These are the nuts that secure the MAF to the airbox: MF434103
Last i need this vacume line shown in the picture. It is from the turbo wastegate actuator to the turbo wastegate solonoid.(it goes into the "T" it is marked with red. I already gave you this part number above. You did not answer my question about the hose for the FPR however.
What's the difference in the panel between 5-speed and the MR's 6 speed, other than the sticker?
Thanks
Thanks
Originally Posted by zaverdi
'MR633547 panel with the shifter and ashtray and the cigarette lighter' for the 5-speed....
Any clue about the 6-speed panel for MR?
Originally Posted by JustDSM
MR512557
Any difference? or mine was wrong?
thanks
I double checked my part number, and what I posted is in fact correct for just that part
The dealer gave you the part number for that panel with all the clips for that piece and the "titanium look" piece that spans across the dash.
Another example of why I ask that you all give me pictures of exactly what you want. Your interpretation of what the part is called, mine and CAPS are not always the same and this leads to wrong part numbes.
The threading to the plate that attaches to the back of the battery tray is stripped out. Does anyone know the part number to that and the bolt that attaches it to the tray?
