All Part Number Request Go Here
Old Dec 13, 2004 | 02:28 AM
  #241
JustDSM's Avatar
What is the front floor console panel? Take a picture of what you need.
Old Dec 13, 2004 | 08:24 AM
  #242
FresnoEVO's Avatar
Old Dec 13, 2004 | 10:47 AM
  #243
sillypuddy's Avatar
Originally Posted by n00dle
MZ530857 Mud Flap Kit Carbon (Evolution)
MZ530855 Mud Flap Kit - Red (Ralliart)
anybody got a picture of these mudflaps?
-joe
Old Dec 13, 2004 | 10:48 AM
  #244
sillypuddy's Avatar
The list so far:
MR633538 Upper Steering column cover
MR232147 Gear link bushing
MF247868 (1) MF140210 (3) MF140206 (6) Cam cover bolts
MR572609 Board, trunk room floor
MR444269 Trim, Trunk room RR end (Grey)
MD050316 Oil drain plug
MD569372 M/T plug
MB547806 Clip, Engine Room Cover
MZ690116 oil filter
MR552951 air filter
MR407376 Front pad kit (hardware sold separately)
MR407391 rear pad kit " "
MD979313 water pump
MN158794 alternator belt
MD186785 spark plug grommets
MD340535 valve cover gasket
MD152772 pcv valve
MN132206 clutch disc
MR980846 pressure plate
MR145619 T/O bearing
MD746617 clutch slave cylinder
MR491945 clutch master cylinder
MN149074 crankshaft pulley
MR370723 front brake rotors
MN153010 oxygen sennsor frt
MR578532 rear oxygen sensor
MD327107 cam position sensor
MR578117 knock sensor
MD363552 ignition coil
MD343245 plug wires set
MD374841 spark plugs
MR455707 lug nuts
MB911495 wheel studs (frt or rear)
MR984375 timing belt adjuster
MD369999 timing belt pulley
MD569372 air intake rivet thingy
MR288876 hood vent rivet thingy
MR975089 coin box
mn153356 BODY ASSY,AIR CLEANER (Stock Airbox)
mr578399 SENSOR,AIR CLEANER (MAF SENSOR)
MN153284 bov
MN126274 Insulator, Hood
MR475929 Left caliper
MR475930 Right caliper
MZ598263 CD Changer Install kit
MR626799 cd changer panel only, no rails (black)
MR554814 RH Lower Control Arm Asm.
MR554813 LH Lower Control Arm Asm. (this is an assumption based on left right part#)
MB914617 Front Wheel Bearing Asm.
MD160689 1G Air bypass valve (for anyone using Buschur upper IC)
MU480007 licence plate grommet (square)
MN168249 Gear Shift Lever Retainer (part of the gearshift level)
MR286178 Replacement trunk lock
MR633547 panel with the shifter and ashtray and the cigarette lighter
MN161463 RS ~04/07/31 trunk lid
MN161464 RS 04/08~ trunk lid (no spoiler)
MN150620 RS 04/08~ trunk lid (spoiler)
MN161462 MR trunk lid (spoiler)
MN161463 MR trunk lid (no spoiler)
MR574731 front Mitsubishi symbol
MR975477 intake/trunk carpeting fastener
MB547806 front undertray fastener
MB918617 tiny light that shines into the ash tray
MN143213 stock boost solinoid located under the airbox
MR412407 rs trunk bar
MN101890 MR bilsteins Fronts
MN101899 MR bilsteins Rears
MR647677 the piece that holds the ashtray and the cig lighter
MD372536 cam seals
MN158794 Alternator and other drive belt
MN153284 MR bypass valves
MR970228 black RS door handles Front Right
MR970227 black RS door handles Front Left
MR970268 black RS door handles Rear Right
MR970267 black RS door handles Rear Left
MR450703 donut gasket for the downpipe
MR481252 radiator cap
MR250558 Radio delete panel
MR597271 downpipe bolts
MR597273 downpipe Springs
MR497545 studs on the cat
MR571083 downpipe -> cat (nuts that go on the studs on the cat)
MF241309 cat -> cat-back bolts + nuts
MR627152 interior door handle Front Left
MR627153 interior door handle Front Right
1545A001 MR BOV
MD345681 Rocker cover center cover
MN161534 rear side marker light
MR648031 rear interior door panel (which side?)
MR973540 antenna Base
MR583214 antenna Nut
MR587268 stock radio (evo?)
MD000312 transmission drain plug gasket
MF660036 trasmission fill plug gasket
MD000312 transfer case drain plug gasket
MD000312 transfer case fill plug gasket
MB001294 rear diff. drain plug gasket
MF660036 rear diff. fill plug gasket
MR506482 headlight height adjustment switch
MN126920HB 3rd stoplight cover (You have to get the whole light assy.)
MR580533 teflon shifter cables MR
MN107670 teflon shifter cables GSR/RS
MN143079 timing belt cover lower front
MN153353 Air Cleaner box cover (top)
MD613573 MR Specific Compressor housing
MD613524 MR Specific Turbine housing
MD613567 GSR/RS Specific Compressor housing
MD613521 GSR/RS Specific Turbine housing
MZ380295EX vortex generator
MN155744 Cyl Head
MN143619 Intake Camshaft
MN143620 Exhaust Camshaft
MN137746 Intake Manifold
MN156302 Exhaust Manifold
MN135583 Down Pipe
MR968097 Mid Pipe
MN153192 Rear Section
MR962799 03 Evo's clock
MD356000 MR oil filter
MZ690116 oil filter (normal?)
MR512557 plastic housing arount the clock and hazard switch
MR954150 Right (Passenger Side) Front Fender
MN161172 Right (Passenger Side) Complete Entire Light (Including Housing, HID) (this is the entire assy.)
MR954176 Right (Passenger Side) Front Wheel well Plastic Dirt covering
MN161277 Hood
MS240129 Bolts for gas tank and rear trunk tie bar
MR572500 Clips for the rear trunk liner
MN151260HA MR Mats (both sides?)
MN126980 Front bumper undertray
MN161109XA Black front bumper cover
MN156784 O2 Housing
MR299686 Metal Gasket to Turbine <-- parts to go with the O2 housing
MD132933 4 x Washer
MD062961 3 x Bolt
MR224441 1 x Stud
MD050073 1 x Nut
MN101464 MR Front springs (same part # as GSR/RS)
4140A007 MR Rear springs
MR538851 Fog Light relay
MB914617 Front wheel hub assembly
MN153285 front mount intercooler
MN126784HC Lower lip of front clip (comes pre-painted)
MN126771 intercooler grille
MN126979 Left Undertrays w/ brake cooling ducts
MN126980 Right Undertrays w/ brake cooling ducts
MR379950 Center Undertrays w/ brake cooling ducts
MN126784 HC (Pre-painted) EVO8 FRONT AIRDAM LIP
MN126981 PANEL UNDERCOVER FRONT
MN126979 PANEL UNDERCOVER FRONT CENTER
MR109421 diamond trunk badge for a 1999 Galant.
Old Dec 13, 2004 | 12:00 PM
  #245
FresnoEVO's Avatar
Originally Posted by FresnoEVO
If this is
Sorry for re-requesting.... still looking for part numbers for the left and right plastic covers that go over the a-pillars...and the metal clips that go on it if they are a different part number
much thanks
rob
Old Dec 13, 2004 | 04:12 PM
  #246
webguy330i's Avatar
Anyone know the part # for the (I presume same for driver and pass. side) lower front caliper mounting bolt? There should be a lower and an upper.
Also any idea on the size/pitch of the bolt?
Old Dec 13, 2004 | 04:49 PM
  #247
hel_if_ino's Avatar
Originally Posted by sgplancer
JustDSM
Any luck on the rear O2 sensor pig tail? Thanks for any update.
hey, this is where i bought mine from, saved me an *** ton of money.
https://www.automedicsupply.com/cata...da302fa7d3dfc3
Old Dec 13, 2004 | 04:50 PM
  #248
hel_if_ino's Avatar
Hey Justin, I have everything i need finally for the intake box, since mine was lost in the move, but i need the bolts that bolt the bracket of the intake box down to the engine bay, thanks in advance! Also, there are two bolts that hold down the radiator overflow tank, I need those bolts, thanks!
Old Dec 13, 2004 | 08:19 PM
  #249
JustDSM's Avatar
MR647677
Your A-Pillar's are:
Left: MR631941
Right: MR631943
Old Dec 13, 2004 | 08:30 PM
  #250
JustDSM's Avatar
Bolt: MR370729
Washer: MR407072
I can only see it is a 12mm bolt 35mm long. No idea on thread pitch. I suspect 1.25 though
Old Dec 13, 2004 | 08:49 PM
  #251
JustDSM's Avatar
Air box bracket bolts: MS240121
Overflow bolts: MS240142
Old Dec 13, 2004 | 10:36 PM
  #252
webguy330i's Avatar
Originally Posted by JustDSM
Bolt: MR370729
Washer: MR407072
Thanks man!!
Old Dec 15, 2004 | 06:07 AM
  #253
sillypuddy's Avatar
anybody know what parts i need to retrofit the rear wiper onto a non-evo model? (i figure i will need the rear motor, the arm, etc)
-joe
Old Dec 15, 2004 | 08:42 AM
  #254
[TYPE]SS's Avatar
just a quick question, which online mitsubishi part store is the cheapest??
Old Dec 15, 2004 | 10:24 AM
  #255
JustDSM's Avatar
I use Mitsubishiparts.net for the ease of use. I don't know if they are the cheapest.
