All Part Number Request Go Here
Old Dec 1, 2004 | 08:25 AM
  #211
JustDSM's Avatar
drummerjun: I'll have those numbers for you shortly.
ez76: I have posted those on the forums here. Search this thread, if nothing turns up, take a look in Gruppe-S's forum. They are in one of those.
Old Dec 1, 2004 | 08:14 PM
  #212
Seth's Avatar
Originally Posted by johnnysixer
O2 sensor housing #?
O2 Housing: MN156784
Metal Gasket to Turbine: MR299686
4 x Washer: MD132933
3 x Bolt: MD062961
1 x Stud: MR224441
1 x Nut: MD050073
Old Dec 1, 2004 | 09:14 PM
  #213
JustDSM's Avatar
MR Front springs: MN101464 (same part # as GSR/RS)
MR Rear springs: 4140A007
Old Dec 1, 2004 | 09:46 PM
  #214
JustDSM's Avatar
Fog Light relay: MR538851
You're going to have to be a little more specific about which harness you need. Their are several.
Old Dec 2, 2004 | 12:34 AM
  #215
JustDSM's Avatar
Originally Posted by The Bear
Hello
This is really awesome of you to take the time and help us out with this stuff! It's much appreciated!
What are the part #s for the GSR and base Lancer floor mats? And does anyone know if they both fit the same?
Also, part #s for all of the shop/service/repair manuals (soft and hardcopies if available) for the 2005 Evos would be great.
Thats all I can think of for now.
Thanks
Thank you for your post. I'm glad to hear it's appreciated. I enjoy helping out.
Mitsu only seems to list the floor mats as being avail. with the carpet. Much the same as I posted for the individual requesting mats from a MR. The base Lancer does have a different part number.
I do not have access to the part numbers for them. They are avail. here (although '05 is not yet listed):
http://www.mitsubishiparts.net/catalog/?section=315#562
Old Dec 2, 2004 | 12:37 AM
  #216
ez76's Avatar
Justin you are the MAN
Old Dec 2, 2004 | 12:41 AM
  #217
drummerjun's Avatar
Thanks very-a-much for the help.
As for the wiring harness, I need to wire the fog light switch (which I already have) to the relay.
Old Dec 2, 2004 | 05:03 PM
  #218
en1gma19's Avatar
does anyone know that part number for the hub at the bottom of the wheel assembly that has the bolts that the lugnuts screw onto.
Old Dec 3, 2004 | 05:23 PM
  #219
dsm95hybrid's Avatar
Front end parts request
Hi guys, "Rally" the raccoon decided to pay a visit to the front of my intercooler a few days ago.
Can someone help me with the part numbers and list prices of these items:
FMIC
Lower lip of front clip
intercooler grille
Undertrays w/ brake cooling ducts- 3?
Any other parts #'s relative to the front end damage.
Thanks in advance!
FMIC3
FMIC4
Old Dec 3, 2004 | 08:14 PM
  #220
JustDSM's Avatar
I'm assuming by your description that you need the front wheel, hub assy. That part is: MB914617
Old Dec 3, 2004 | 08:16 PM
  #221
JustDSM's Avatar
Guys. Do me a huge favor when you make a post requesting a part number. If you are unsure of the name of the part or even have a slight doubt about what to call the part you need. Please post up a picture. It makes it alot easier on me.
Thanks!
Old Dec 3, 2004 | 08:23 PM
  #222
JustDSM's Avatar
FMIC MN153285
Lower lip of front clip MN126784HC (comes pre-painted)
intercooler grille MN126771
Undertrays w/ brake cooling ducts- 3? Left: MN126979, Right: MN126980, Center: MR379950
Any other parts #'s relative to the front end damage. See below
Thanks in advance!
I cannot honestly see the extent of the damage. Best bet is to have a body shop look at it and have them give you an idea as to what parts are damaged.
Old Dec 3, 2004 | 08:28 PM
  #223
JustDSM's Avatar
Check the FSM to see if your vehicle is prewired already. You may only need to get the relay and switch.
Old Dec 3, 2004 | 08:48 PM
  #224
EVOla_VIRUS's Avatar
The MR has a different part number than the GSR and RS models. All GSR and RS models ('03-'05) have the same shift cables.
MR: MR580533
GSR/RS: MN107670
Pardon my naive question.....Can the teflon MR shifter cables be used on an '03 Evolution? has anyone done this? Thanks!!
Old Dec 3, 2004 | 09:58 PM
  #225
FMIC MN153285
Undertrays Left: MN126979, Right: MN126980, Center: MR379950.
Alright, Progressive took their pics so I was able to tear down the MR. Here is what I found:
2005 EVO8 MR GRAPHITE GRAY
MN153285 INTERCOOLER
MN126771 INTERCOOLER GRILLE- - Thanks Justin! -couldn't find this...
MN126784 HC (Pre-painted) EVO8 FRONT AIRDAM LIP
MN126981 PANEL UNDERCOVER FRONT
MN126979 PANEL UNDERCOVER FRONT CENTER
MN126980-STILL GOOD --PANEL UNDERCOVER SIDE
Does the "HC" represent the prepainted color?
Dont know if changed the part numbers but the undertrays read
MN126979
MN126980
MN126981
Which are different from your #'s Justin...
Thanks for the quick reponse. I feel better knowing all of the damage & part #'s.
Watch out for the Faulking Raccoons! They'll wreck your S@^#!
