All Part Number Request Go Here
Old Feb 13, 2005 | 08:53 AM
  #361
JustDSM's Avatar
Originally Posted by hbruce16
I need the part number for the sticker that goes on the driver's side inside door panel on a 2003 Evo. It is the one that says the tires are high performance and will wear quicker then regular tires. Also Mitsu recommends using snow tires.... You get the picture. (it's on all Evos, but on the newer ones it's right next to the ACD instruction sticker)
I got my door panel replaced under warranty due to wear on the felt on the trim around the PW switches, but the sticker wasn't on the new door panel.
I really want the sticker and my parts department can't seem to locate it.
thanks in advance...
CAPS does not list the part number for that sticker. Sorry.
Old Feb 15, 2005 | 01:45 PM
  #362
lancerdealer's Avatar
I checked with my PDC and they are looking into it. It doesn't look good but they are checking.
Old Feb 16, 2005 | 02:56 AM
  #363
hawaiievo's Avatar
what about the part # for the center panel. the one with the radio and a/c and stuff like that. i have an RS already but i want the one that macthes the trimming around the shifter and ashtray. (same color) and a price if possible.
Old Feb 16, 2005 | 03:19 AM
  #364
JustDSM's Avatar
Panel: MN151264HA
Labels: MR500935, MR500932, MR568314
Old Feb 16, 2005 | 03:23 AM
  #365
hawaiievo's Avatar
allright thanks and thats not the plain black one right?
Old Feb 16, 2005 | 03:52 AM
  #366
JustDSM's Avatar
That is the GSR spec pannel. It's what you're looking for. No worries.
Old Feb 16, 2005 | 11:47 AM
  #367
hawaiievo's Avatar
cool cool thanks alot
Old Feb 16, 2005 | 07:19 PM
  #368
WeAreDevo's Avatar
Hey Justin, You are THE MAN!
I'm trying to convert my 03 evo back to the stock airbox and BOV. Don't have any of the bits and pieces.
Have gleaned these part numbers from this fantastic thread so far:
mn153356 BODY ASSY,AIR CLEANER (Stock Airbox)
MN153353 Air Cleaner box cover (top)
Air box bracket bolts: MS240121
Overflow bolts: MS240142 Where are these used?
MN143343 hose line for the blow off valve , Is this #13 air intake hose in attached picture?
MN153284 bov
Still Need:
Air Intake Hose
Air Cleaner Bracket
Band Clamps for air intake hose
Band Clamps for BOV
Mass Air Sensor Gasket
Old Feb 16, 2005 | 08:49 PM
  #369
JustDSM's Avatar
Overflow bolts: MS240142 Where are these used? These are for the coolant overflow tank on the passenger side of the car.
MN143343 hose line for the blow off valve , Is this #13 air intake hose in attached picture? Nope, see below for #13. For the hose that comes from the upper IC pipe to the BOV, you'll need MR993869.
MN153284 bov
Still Need:
Air Intake Hose MR571592
Air Cleaner Bracket MN156291
Band Clamps for air intake hose MF661135 & MF661142
Band Clamps for BOV MD173306
Mass Air Sensor Gasket MD151672
Thank you!
Old Feb 17, 2005 | 12:47 AM
  #370
ez76's Avatar
How about the RS transfer case?
Last year tx_evo posted MR498813 but that doesn't come up on mitsubishiparts.net
Old Feb 17, 2005 | 02:00 AM
  #371
JustDSM's Avatar
'04 RS T-Case: MR498813 (Unsure of why it wasnt listed. That is the correct part number. Perhaps their database is not current.?.?)
'05 RS/MR T-Case: 3200A011 (I expect this to change sometime, but this is it for now. This also seems to work on W5M5 and W6MA transmissions as well.)
Old Feb 17, 2005 | 09:29 AM
  #372
RRRS's Avatar
I'm looking for 04' RS driver side A-pillar panel, this is without the tweeter cut-out so maybe any lancer's part# may fit. TIA
Old Feb 17, 2005 | 04:47 PM
  #373
jfh's Avatar
jfh
Could you please post the part numbers for the 4 studs on the turbine housing.
Two of the five fasteners used to conncect the turbine housing to the O2 housing are studs, the remaining three are bolts. Similarly on the exhaust manifold side of the turbine housing two of the four fasteners are also studs and the remaining two are bolts.
I am replacing the turbine housing with a 10.5 and these studs are seized and seem like they will snap before they release so I need to purchase new ones.
thanks
Old Feb 17, 2005 | 07:59 PM
  #374
evoD's Avatar
wondering if anyone has part numbers for wiper blades, front and back please, thanks.
Old Feb 18, 2005 | 06:00 AM
  #375
JustDSM's Avatar
MR644580
