All Part Number Request Go Here
Old Mar 16, 2005 | 09:18 AM
  #421
93civEJ1's Avatar
Originally Posted by JustDSM
MD743612
sweet...thanks!
Old Mar 16, 2005 | 05:41 PM
  #422
93civEJ1's Avatar
how do you know all the part numbers?
Old Mar 16, 2005 | 06:31 PM
  #423
JustDSM's Avatar
I use the program the parts department uses to look them up.
Old Mar 17, 2005 | 05:21 PM
  #424
hkfeet's Avatar
Anyone know the part # for the plastic shifter bracket?
Originally Posted by hkfeet
Ordered a kartboy short shifter kit but he is out of the plastic pivot cap. Anyone know the part # for this?
Old Mar 18, 2005 | 01:50 PM
  #425
jimmyv65's Avatar
What are the P/N's for the 2005 MR shocks/struts--Front and Rear.
Thanks!
Old Mar 18, 2005 | 05:48 PM
  #426
timzcat's Avatar
Hey JustDSM how about the oil feed pipe (turbo) banjo bolt and washers where it connects to the head. I'll post a picture if you need it.
Old Mar 18, 2005 | 06:12 PM
  #427
JustDSM's Avatar
I'm still looking for this one. Some reason it's not where it "should" be.. I'll post as soon as I can locate it.
Old Mar 18, 2005 | 06:13 PM
  #428
JustDSM's Avatar
Thanks!
This has been covered before. It should be located in this thread.
Old Mar 18, 2005 | 06:16 PM
  #429
JustDSM's Avatar
Oil feed line: MR266706
Crush washers (turbo side): MF660064
Banjo bolt (turbo side): MS650013
Banjo bolt (head side): MF650102
Crush washers (head side): MF660063
Old Mar 18, 2005 | 06:42 PM
  #430
Thegame's Avatar
How about the part # for the big long piece of dash right below the windshield? (The one with the vin# plate and defroster vents)
Old Mar 18, 2005 | 06:49 PM
  #431
hkfeet's Avatar
No worries I emailed kartboy and he will have some in stock on Monday. Thanks though
Old Mar 18, 2005 | 08:01 PM
  #432
JustDSM's Avatar
Let us know what you find out!
Old Mar 18, 2005 | 08:02 PM
  #433
JustDSM's Avatar
Garnish, Defroster: MR626743
Old Mar 18, 2005 | 08:13 PM
  #434
timzcat's Avatar
You rule.
Would you happen to know if the MF660063 is the pair of them or individual part (requires 2)?
I can tell you the Banjo bolt is pretty crappy. At 13 ft lbs it stretched at the feed hole in the sides and started to twist. Defintely requires using the inch lb. torque wrench at 144.
Old Mar 18, 2005 | 08:40 PM
  #435
JustDSM's Avatar
Anytime.
The part number will get you one crush washer. You'll have to specifiy 'two'
