All Part Number Request Go Here
Old Apr 4, 2005 | 02:30 PM
  #466
JustDSM's Avatar
Originally Posted by spoolingEVOx
Justin,
Do you have the p/n for the plastic fasteners that i would use on a radiator cooling shroud?
They are located on the factory radiator support.
Clips into the bumper cover: MU488006
Clips into the radiator support: MR200300
Old Apr 4, 2005 | 02:37 PM
  #467
webguy330i's Avatar
lubes and such
So I've been searching around and looking through this thread, but I cannot find a conclusive list of lube part #'s for the evo.
I'm curious about the 2003 specifically, but if they are different per year can someone list those too?
Looking for:
engine oil
transmission fluid (I understand this is only available in a 5gal bucket)
center diff (transfer case) fluid
rear diff fluid
And of course, for front-diff cars, there's a front diff fluid part # as well.
Many thanks!
Old Apr 6, 2005 | 07:51 PM
  #468
timzcat's Avatar
Exhaust Manifold to turbo gasket
Intake manifold gasket
Valve seals (Are E and I different?)
Cooling housing where it meets the cylinder head (housing has t-stat and all sensors on it)
CHRA
Fuel rail feed o-ring or gasket
Fuel rail return o-ring or gasket
Throttlebody gasket
Oil pan
Oil drain tube to turbo gasket
From left field the recirc door for the HVAC system, it is right behind the glove box door and can be seen.
Edit: By the way, can you look up an older 4G63 head for those cam cap dowel pins? At this point I am looking for a junk head to get them out of. Thanks
Hopefully I will leave you alone after this.
Old Apr 6, 2005 | 08:24 PM
  #469
JustDSM's Avatar
Looking for:
engine oil
rear diff fluid
Many thanks!
I'm sorry, but I'm not able to look these up. I'm digging as I'm interested in the part number for the Mitsubishi Diamond Gear Oil (5 gal bucket). Mitsu suggests using the Diaqueen for the transfer and rear end.
Old Apr 6, 2005 | 08:31 PM
  #470
timzcat's Avatar
3775610 is the diaqueen on the container and the dealer part delivery sticker no lettered part # on it. (MD,MR, etc)
Old Apr 6, 2005 | 08:38 PM
  #471
JustDSM's Avatar
Originally Posted by timzcat
Exhaust Manifold to turbo gasketMR323654
Intake manifold gasket 1540A019
Valve seals (Are E and I different?) Yes, Intake: MD306079 / Exhaust: MD307343
Cooling housing where it meets the cylinder head (housing has t-stat and all sensors on it) MN143307
CHRA MD613507
Fuel rail feed o-ring or gasket FPR O-ring: MD604696
Fuel rail return o-ring or gasket Return line O-ring: MB554317
Throttlebody gasket MD180361
Oil pan MN163343
Oil drain tube to turbo gasket MR258477
From left field the recirc door for the HVAC system, it is right behind the glove box door and can be seen. I'm going to need a picture
For the cam cap dowels... Perhaps you can point me exactly what you're looking for in the photo below:
Old Apr 6, 2005 | 08:39 PM
  #472
JustDSM's Avatar
Correct. I've got two of these.. I had written down the Diamond stuff once, but I've misplaced it.
Old Apr 6, 2005 | 08:59 PM
  #473
timzcat's Avatar
Holy crap I think you got it!
Circled in pic 01297
I'll get the pic of that hvac door
Old Apr 6, 2005 | 09:14 PM
  #474
timzcat's Avatar
Arrows pointing at it. There is a grd that is part of the box. The door is directly behind it and seals up the area.
File Type: pdf
Old Apr 6, 2005 | 09:17 PM
  #475
JustDSM's Avatar
MD132806
Old Apr 6, 2005 | 09:22 PM
  #476
timzcat's Avatar
That's got to be it. Bushing - cylinder
You just saved me a **** load of aggrivation and time.
Thank you Thank You Thank You
Old Apr 6, 2005 | 09:23 PM
  #477
JustDSM's Avatar
BTW: Your PDF isnt working for me..
I'm glad I could help.
Old Apr 6, 2005 | 09:25 PM
  #478
timzcat's Avatar
btw the CHRA is $800!!!
I guess I will have to look up the shaft play spec cause I have some and it only has 6000 miles on it. Doesn't make much sense.
Old Apr 6, 2005 | 09:28 PM
  #479
timzcat's Avatar
That's odd. Coverted it to jpeg
Old Apr 6, 2005 | 09:30 PM
  #480
timzcat's Avatar
I am going to do the total part number list thing again in the next couple of days and have a General mod put it at the beginning so everyone can see it.
