All Part Number Request Go Here
Old Apr 11, 2005 | 02:43 PM
  #496
JustDSM's Avatar
Originally Posted by nubby
What is the part number for the roof skin? It's #30 in this drawing. Any idea what these cost?
No sunroof: MR548949
W/ sunroof: MR548950
Old Apr 11, 2005 | 02:44 PM
  #497
JustDSM's Avatar
Originally Posted by ez76
part # ID on the bracket/bolts?
MF244879
Old Apr 11, 2005 | 02:47 PM
  #498
JustDSM's Avatar
Originally Posted by timzcat
Justin, that number for the cooling housing gasket you gave me is the actual housing itself. I just need the gasket.
I also would like that part number for an EGR valve gasket and a PCV hose (cam cover to intake manifold)
Head-Coolant housing gasket: MD363254
EGR Valve gasket: Not sold seperately from the valve. This sucks.
Old Apr 11, 2005 | 02:51 PM
  #499
JustDSM's Avatar
Originally Posted by Russell K
Could you please provide me with the part numbers for all 4 motor/transmission mounts? I only need the mounts' part numbers and not the brackets they are mounted in unless thats the only way they come from Mitsubishi. I have labeled the parts I need in the pictures provided. I labeled them 1,2,3,& 4. I need these part numbers because I will be working with an individual who might be willing to fill the stock mounts with polyurethane. They need the factory mounts to make prototypes. See this thread https://www.evolutionm.net/forums/sh...89#post1847489 for more details!
Thanks Again!
Russell K
MR491558
MR594455
MR554434
MR554653
Old Apr 11, 2005 | 04:06 PM
  #500
timzcat's Avatar
Uh, really? I threw it out already.
Time to hit the trash can.
Hey for another member here can you give me the boost solenoid hose set part number.
Thanks
Edit: Just a thought. IS the manifold the picture that shows the EGR? I am wondering if it is in another pic. I am going now to find it.
Old Apr 12, 2005 | 08:36 AM
  #501
JustDSM's Avatar
Try this: MD119127
It's the EGR valve gasket from the 1G Eclipse and at a $1.87 you might try it and let us know.
Old Apr 12, 2005 | 12:02 PM
  #502
Russell K's Avatar
Are those part numbers for the mounts in the order in which I labeled them? I would really appreciate it if you could tell me, I really need to know!
Thanks Again,
Russell K
Old Apr 12, 2005 | 12:38 PM
  #503
Russell K's Avatar
Can you please also give me the part numbers for all the bolts and nuts circled in red in the following pictures? I have the bolts and nuts I need numbered from 1 to 10. Could you please label the part numbers 1 through 10 for me? I am trying to figure out a few things about these motor mounts and need to purchase all this stuff to give to a fabricator. I cant tell you how much this is helping me right now. If it wasnt for you and this thread, I would have to spend hours hunting this stuff down!
Thanks,
Russell K
Attached Thumbnails All Part Number Request Go Here-lower-mounts-bolts-nuts.jpg   All Part Number Request Go Here-top-drivers-side-mount-bolts-nuts.jpg   All Part Number Request Go Here-top-pass-side-mount-bolts-nuts.jpg
Old Apr 12, 2005 | 01:02 PM
  #504
JustDSM's Avatar
Thanks,
Russell K
1: MU100027
2: MB176638
3: MF104928
4: MF434106
5: MR235604
6: MF434105
7: MF140469
8: MF434105
9: MF140273
10: MF434105
Old Apr 12, 2005 | 01:03 PM
  #505
JustDSM's Avatar
Thanks Again,
Russell K
I didn't even look. I saw that you were looking for all the mounts, and I just posted them in the order that I clicked them. Either way, if you order those parts, you'll have what you need regardless of what order they are in.
Old Apr 12, 2005 | 02:43 PM
  #506
Russell K's Avatar
Thats true, but I needed to know that info so I can place two or three seperate orders for these. I plan on buying one at a time, and I need to know which ones to buy. I will be buying the front and rear lower mounts seperately (ASAP) and sending them to different fabricators to help find a solution to our lack of aftermarket motor mounts. Any way that you could help me would be appreciated. If not, I will have to go to the dealer (its quite a drive for me) with part numbers in hand to ask them which is which. Sorry, I am not trying to be difficult! I am just trying to save myself some gas and time.
Thanks,
Russell K.
Old Apr 13, 2005 | 12:50 PM
  #507
93civEJ1's Avatar
Part number for the Bigger O-ring that goes between the tcase and tranny (ive already got the top small one), need the one that goes around the shaft in between t-case and tranny.
Also, if possible, the little bracket that bolts to the tranny with 2 -12mm screws that the smallest shiftlinkage bushing goes on. Just need that little arm assembly, as circled below. Maybe also the little white block that the top peice slides on.
Old Apr 13, 2005 | 05:25 PM
  #508
Daveyd's Avatar
Whats the part number of the OEM red Valve Cover?
Old Apr 13, 2005 | 07:30 PM
  #509
Daveyd's Avatar
bumpski
Old Apr 14, 2005 | 01:41 PM
  #510
Russell K's Avatar
Can you please provide me with the part numbers for the Transmission, Transfer Case and Rear Differential drain and fill plugs?
I still need to know which motor mount is which?
Thanks Again,
Russell K.
