All Part Number Request Go Here
Old May 18, 2006 | 05:09 PM
  #1066
oak2207's Avatar
Here is the part number for the oil drain plug crush washers, available from mitsubishiparts.com:
MD050317 Drain Plug Gasket
Old May 18, 2006 | 09:07 PM
  #1067
timzcat's Avatar
Originally Posted by RRRS
are these crush washers same as "copper washers" mentioned on other threads?? also, are they the same washers for the coolant lines into the turbo? and lastly, do i really need the eye bolts? are they known to leak if not replaced?
i'm in the proccess of collecting these parts for a TME swap, thanks very much.
Yes they are copper.
The problem with the eye bolts is they are not real strong. When I installed mine back to the head I torqued it to spec and the torque wrench wouldn't click so I removed it and it stretched out. They are not strong and it is a good idea to have a spare.
Old May 20, 2006 | 05:05 AM
  #1068
SuperHatch's Avatar
Originally Posted by mdosu
I need PN verified for 2003 EVO glass, not Lancer glass
okay, I got 3 part numbers from my dealer and prices and they seem to conflict, I absolutely need someone to verify these numbers with me. So please help.
Thanks!
Evo glass MR991637 $439.87
Early model Lancer glass MR533951 $422.95
Late model Lancer glass Mr991638 $816.33
Evo Glass - MR991637 $439.87 list, $335.18 from mitsubishiparts.net
Old May 20, 2006 | 05:12 AM
  #1069
SuperHatch's Avatar
The coolant line washers are not the same as the oil line washers...
Oil line crush washers at head.... MF660063 (2)
Oil line crush washers at turbo.... MF660064 (2)
Coolant line crush washers.... MF660065 (4)
Replacing the bolts is a good idea but not necessary as timzcat said.
MS650013 - oil feed bolt (1)
MF650114 - coolant line bolts (2)
It is also a good idea to replace the soft rubber coolant lines, they are cheap and known to leak.
MD363256
MD082347
- Steve
Old May 20, 2006 | 05:14 AM
  #1070
SuperHatch's Avatar
Originally Posted by eling99
part number for center bolts for the front upper strut bar?
Thanks
MS240592
Old May 20, 2006 | 06:13 AM
  #1071
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
Need to know the part number for the 06 Evo 9 spark plug cover. Obviously the
03-05 have "MITSUBISHI" on them. I like the 06's style with just the "Diamond Star' logo. Not sure if part numbers are the same. Thanks!
Old May 20, 2006 | 10:56 AM
  #1072
eling99's Avatar
Originally Posted by SuperHatch
MS240592
Thanks
Old May 20, 2006 | 01:21 PM
  #1073
RRRS's Avatar
thanks again, timzcat & superhatch.
Old May 22, 2006 | 03:24 PM
  #1074
KevOVIII's Avatar
MD363256
MD082347
- Steve
Would you happen to know what the part numbers are for the coolant hard lines that come off/into the turbo? Thanks.
Old May 24, 2006 | 12:35 PM
  #1075
jdmstop's Avatar
anyone know what the part number for the bulb's thats lights up the instructment panel? ie the rpm and speed.
Thanks
Old May 25, 2006 | 05:50 PM
  #1076
EvoRicer's Avatar
P/N for the Rear O2 Sensor for the IX's?
Old May 25, 2006 | 05:58 PM
  #1077
kErViOsVIII's Avatar
does anyone know the P/N for the smaller of the 2 covers for the fuse box under the hood?
Old May 28, 2006 | 12:16 PM
  #1078
Sap12687's Avatar
How about tranny bolts on an VIII
Old May 29, 2006 | 12:52 PM
  #1079
SuperHatch's Avatar
MN143305 - Return
MD363253 - Feed
Old May 29, 2006 | 12:54 PM
  #1080
SuperHatch's Avatar
Thanks
MR444537
