All Part Number Request Go Here
Old Mar 24, 2008 | 05:03 PM
  #2431
RussellM's Avatar
Plat Vendor
Originally Posted by kmcconn9
I need the white expandable (retaining) clip shown in this picture..
Thanks!
The clip is under the black boot thing.??
What is that a picture of?
Old Mar 24, 2008 | 05:05 PM
  #2432
RussellM's Avatar
Plat Vendor
Originally Posted by TS8
Please help with # for two light bulbs inside the Heat/Vent/AC Control unit, and
the bulb inside the Hazard lamp switch. Thank you, Toshi.
LINK -- No bulb for the hazard switch. Complete switch is in the link.
http://www.mitsubishiparts.net/cart/...769*2+MR406456
Old Mar 24, 2008 | 05:06 PM
  #2433
RussellM's Avatar
Plat Vendor
Originally Posted by tim85851
theres so many pages but does anyone have the part number for the rear view mirror on the 2005 Evo VIII...i dont think theres a difference between the VIII or IX...so either one will do fine...thanks!
LINK
http://www.mitsubishiparts.net/cart/?id=571&pn=MN124448
Old Mar 24, 2008 | 05:15 PM
  #2434
RussellM's Avatar
Plat Vendor
Originally Posted by audison
Is the wiring harness for the stock MR gauges(temp/volt/boost) available for separate purchase? Also, all hoses/parts needed to install the stock IX BOV. Last, the stock vacuum hose to remove and replace the MBC. Thanks Russell!
Here is a link for the hoses you are after -- the wiring I would need to call Mitsubishi on because it is considered an accessory. I dont think Im going to be able to get that stuff by itself.
LINK
http://www.mitsubishiparts.net/cart/...2A165+MN143211
Old Mar 25, 2008 | 12:35 PM
  #2435
draconx's Avatar
whats the part numbers for the two coolant lines on the throttle body?
Old Mar 26, 2008 | 04:57 AM
  #2436
Jazzie604's Avatar
Originally Posted by Jazzie604
is there a part number for the LSD front diffs? the one commonly used to upgrade the 03s?
any chance of getting this?
Old Mar 26, 2008 | 06:22 AM
  #2437
RussellM's Avatar
Plat Vendor
They are different between the VIII & IX so there are two links below, I put the clips on there too. They look like clamps in the image in CAPS, but its not very clear.
VIII
http://www.mitsubishiparts.net/cart/...266+MS660240*4
IX
http://www.mitsubishiparts.net/cart/...086+MS660240*4
Old Mar 26, 2008 | 06:28 AM
  #2438
RussellM's Avatar
Plat Vendor
Those are sold in the T/Case MMNA on the USDM models. They were available through Ralliart and there are some aftermarket vendors who have them. Do some searching around or make a "WTB" post.
Old Mar 31, 2008 | 10:21 AM
  #2439
VR4orceCJ's Avatar
Cool
Need the current 5-Speed Shifter Cable Bracket part number... previously provided as MR980727, but that part number is not recognized as valid on your site. Not Available or new #?
Doing the MR 6 to 5-Speed Conversion...
Thanks
Old Apr 1, 2008 | 11:57 AM
  #2440
crisdawg's Avatar
I'm trying to find the part number of the square clips that hold the shifter cables into the bracket in the engine bay.
I did a clutch install and screwed these up a little and just wanna make sure none of the cables come out during hard driving, thanks!
Old Apr 2, 2008 | 10:34 AM
  #2441
marksae's Avatar
Can someone verify if the IX intake manifold p/n is different than the VIII intake manifold? The VIII's IM p/n is MN137746.
TIA!
Old Apr 3, 2008 | 11:24 AM
  #2442
rentua's Avatar
2003 Evo w/ Large Spoiler
I'm looking for the Part Number for the Tape/Gasket/Seal between the Spoiler and the Trunk Lid.
Thanks!
Old Apr 4, 2008 | 11:13 AM
  #2443
kmcconn9's Avatar
It is the OEM fuel pump.
Old Apr 5, 2008 | 04:18 AM
  #2444
prostcj's Avatar
Could someone help me with the part number of this 1/8 bspt plug? Thanks.
Old Apr 5, 2008 | 08:59 AM
  #2445
TS8's Avatar
TS8
Please help with part numbers for instrument cluster bulbs.
Is it MR444536 or MR444537?
Which one is the larger tach/speed bulb, and which is the smaller "warning" /signal bulb? Thank you, Toshi
