All Part Number Request Go Here
Old May 15, 2008 | 08:52 PM
  #2506
BGR's Avatar
BGR
Sorry guys, I meant to say oil temp, not pressure (long day at work!). So, if I'm to go to the dealer, I have to tell them I need the entire gauge set and it will come with the draing plug with wire?
Old May 15, 2008 | 08:53 PM
  #2507
BGR's Avatar
BGR
Sorry, meant to say temp, not pressure
Originally Posted by cfdfireman1
Drain plug that measures oil pressure? How does that work?
Old May 15, 2008 | 08:54 PM
  #2508
BGR's Avatar
BGR
Do you know the part number for the set? I have a whole sale account at so depending on what the price is I may try to buy it new. Thanks!
Originally Posted by biggie5252
It's oil temp, not pressure. I've heard that you can't get it by itself, you have to order the whole gauge set to get it. You might try ebay.
Old May 15, 2008 | 08:55 PM
  #2509
BGR's Avatar
BGR
Any idea what the problem might be? The gauge going bad or the sensor on the plug? Thanks.
Sounds like that won't fix his problem then.
Old May 16, 2008 | 09:03 PM
  #2510
kreo's Avatar
Originally Posted by RussellM
Do you have an VIII or IX?
ix
thanks
Old May 18, 2008 | 07:31 PM
  #2511
Inflation's Avatar
What about the light bulbs in the tac cluster. I went to Auto zone, O Rielys, Advance auto, and pep boys and they didn't carry the right type of bulbs.
Old May 19, 2008 | 09:13 AM
  #2512
Elu's Avatar
Elu
adjustment knob for the driver side seat on an viii?
Old May 19, 2008 | 11:28 AM
  #2513
RussellM's Avatar
Plat Vendor
Originally Posted by kreo
ix
thanks
LINK
http://www.mitsubishiparts.net/cart/?id=571&pn=MR969153
Old May 19, 2008 | 11:31 AM
  #2514
RussellM's Avatar
Plat Vendor
There are several different bulbs in that cluster and I have no idea which goes to the tach. If they are capped bulbs then its pretty easy.
BULB - WHITE CAP - 8180A001
BULB - BLUE CAP - MR444537
BULB - MN134600
BULB - MR444536
Old May 19, 2008 | 11:32 AM
  #2515
RussellM's Avatar
Plat Vendor
LINK
http://www.mitsubishiparts.net/cart/?id=571&pn=MR789090
Old May 19, 2008 | 11:33 AM
  #2516
RussellM's Avatar
Plat Vendor
Its not a whole gauge set you need. You can buy just the oil gauge with the temp sensor. What color are your gauges?
Old May 19, 2008 | 11:46 AM
  #2517
EVO8LTW's Avatar
The eccentric cam-like bolts and nuts that you use to set the rear toe and camber are in bad shape on my car. Anyone have the PNs for the replacement hardware (bolts and nuts for both sides)?
Thanks.
Old May 19, 2008 | 03:17 PM
  #2518
Inflation's Avatar
BULB - MN134600
BULB - MR444536
What about the fasteners that the bulbs go into?
Old May 19, 2008 | 04:45 PM
  #2519
inco9nito99's Avatar
Interior Bulb Part #'s.
Part numbers for the following if anybody had on hand?
Bulb with twist lock mechanism for ACD button (TINY bulb)..
Bulb for the cig. lighter
Old May 19, 2008 | 04:53 PM
  #2520
thatsMR2u's Avatar
try this thread also
https://www.evolutionm.net/forums/sh...highlight=part
