All Part Number Request Go Here
Old Sep 11, 2008 | 11:04 AM
  #2791
Elu's Avatar
Elu
need to know the part # for the bulb that goes in the upper corner headlight. It's the bulb in section above the turn signal/hazard light.
Old Sep 11, 2008 | 01:07 PM
  #2792
MadCrix's Avatar
part number for the idle control valve? evo 8
Old Sep 12, 2008 | 04:55 PM
  #2793
ksaegusa's Avatar
hello, i think i read somewhere in this thread that a:
FMIC for a evo 8 mr is - MN153285
is this the same for the evo 9? have the evo's in america always had the same stock intercooler?
Thanks for your time
Old Sep 15, 2008 | 08:10 AM
  #2794
awdcomplex's Avatar
evo8 spark plug cover with " mitsubishi" lettering
Old Sep 15, 2008 | 08:20 AM
  #2795
bayrider's Avatar
Anyone know the P/N for an Evo 9 spark plug cover? TIA!
Old Sep 16, 2008 | 08:41 AM
  #2796
Spins4's Avatar
Originally Posted by burnings
What is the part number for Evo X MR interior CF panel and door CF panel?
8002A196HC, and the door piece can not be ordered seperate.
Originally Posted by jwick76
By the wiring harness, i mean the wiring connector that goes from the parking lamp to the bracket on the other side of the headlamp unit, which then plugs into the car wiring.
As for the headlamp support, I will take a pic later today with an arrow...
Thanks!
The only part number Mitsu has for a "pigtail" for a front turn signal on an Evo is MB943605...
MS820090 .. but I'm pretty sure it's just a 194 bulb
MD628318
That is correct, the part number, and the fact that they all shared the same fmic.
MD345681
1035A249
Old Sep 16, 2008 | 08:48 AM
  #2797
CGroovy2k2's Avatar
part number of the bolts for the cam gear cover
Old Sep 16, 2008 | 08:52 AM
  #2798
Spins4's Avatar
The shorter ones are MF140206, and the longer ones are MF140210
Old Sep 16, 2008 | 08:53 AM
  #2799
CGroovy2k2's Avatar
Thx
Old Sep 16, 2008 | 09:05 AM
  #2800
Spins4's Avatar
Thx
np
Old Sep 16, 2008 | 12:54 PM
  #2801
bayrider's Avatar
MD628318
MD345681
1035A249
Thank you sir!
Old Sep 23, 2008 | 09:22 PM
  #2802
biggie5252's Avatar
MR BBS Centercaps and Driver's side rear plastic fenderliner that clips to the rear bumper. Thank you.
Old Sep 24, 2008 | 06:22 AM
  #2803
Spins4's Avatar
MN184312 and MR954177
Old Sep 24, 2008 | 02:43 PM
  #2804
HxllxMan's Avatar
Is there a part number for a brand new evo 8 chassis ? in case i crash mine during rally?
Old Sep 24, 2008 | 03:50 PM
  #2805
Spins4's Avatar
Not a whole assembly per-say...but if you have access to a fax, I don't mind printing out some CAPS pics of everything just in case. It won't have the part numbers, but it will have code numbers to give me if you ever need the actual part numbers.
