All Part Number Request Go Here
Old Jul 16, 2008 | 08:26 AM
  #2641
RussellM's Avatar
Plat Vendor
Originally Posted by justchil
I have a question about a couple orders placed several weeks ago with mitsubishiparts.net .... Do one of you guys work for them?
I do, what are you needing to know?
Old Jul 16, 2008 | 09:24 AM
  #2642
sem23tex's Avatar
Originally Posted by RussellM
Here is a link. Generally if you are careful you can reuse most of your old door panel clips. If you wanted to go ahead and buy them just in case you could factor in another $15-$20 for those little things. Link for the cowl and door trim panel below.
http://www.mitsubishiparts.net/cart/...48020+MN161351
For the cowl do I need to purchase both items? I just damaged the plastic grille that keeps debris from getting into the engine and air vents?
Thanks,
JD
Old Jul 16, 2008 | 09:42 AM
  #2643
Spins4's Avatar
Thanks,
JD
No..the one that is on the drivers side is MR533285...and the one that is on the pass. side is MR533286
Old Jul 16, 2008 | 04:06 PM
  #2644
max2evoix's Avatar
anyone know this part number? evo ix
its the plastic piece that goes over the hid bulb that screws in the headlight..
this round piece shown on this pic facing you..
thanks for any help guys
Old Jul 16, 2008 | 04:08 PM
  #2645
JDMCT9MR's Avatar
Have you tried here?
https://www.evolutionm.net/forums/sh...24376&page=177
Old Jul 16, 2008 | 04:17 PM
  #2646
max2evoix's Avatar
Originally Posted by JDMCT9MR
im talking about the round piece that goes on top of the hid light so that nothing can get into it..and screws on
Old Jul 16, 2008 | 04:26 PM
  #2647
max2evoix's Avatar
bump
Old Jul 16, 2008 | 04:38 PM
  #2648
max2evoix's Avatar
bump
Old Jul 16, 2008 | 04:39 PM
  #2649
gsrboi80's Avatar
PM RusselM mitsubishiparts.net
Old Jul 16, 2008 | 04:41 PM
  #2650
djfmf's Avatar
I need the part number for a Mitsubishi Evolution I Master Cylinder for the clutch. if there was a better part number for the EVO I as an aftermarket replacement I will take that as well. The clutch pedal is just getting to hard to depress at times, it's an on and off thing. And maybe Clutch Line replacement numbers as well since I am replacing the cylinder.
Old Jul 16, 2008 | 04:43 PM
  #2651
gsrboi80's Avatar
Here you need this
http://www.trademotion.com/partlocat...layCatalogid=0
Old Jul 17, 2008 | 05:46 AM
  #2652
Spins4's Avatar
MN175430
Old Jul 17, 2008 | 04:04 PM
  #2653
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
Need the part number for the two 10MM bolts that secure the fuel rail to the fuel return line. Thank you!!!!!
Old Jul 18, 2008 | 05:26 AM
  #2654
Spins4's Avatar
MU240020 ..
And in case anyone is interested, the 2 bolts to bolt the fpr on is MF241223.
Old Jul 20, 2008 | 08:07 AM
  #2655
Fast-Mover's Avatar
Anyone have the part number for the Front radiator fan, Or i guess its called the condensor fan.
