All Part Number Request Go Here
Old Nov 4, 2014 | 05:00 PM
  #4141
06MREvo's Avatar
Originally Posted by 06MREvo
Alright guys, I am looking for a couple part #s for some firewall, harness mounting hardware!
This is for the section of harness that goes from the main fuse box along the driver's side frame rail, along the fire wall then through the firewall & under the dash. A lot of this harness is inside black plastic covers. There are (5) pieces of hardware total.
(1) 12mm bolt - Holds harness to driver's side frame rail, (3) 10mm nuts - Hold harness to firewall & (1) 10mm bolt - holds harness to firewall <<(Last bolt before it goes through the firewall & under the dash).
If anyone has a good engine bay wire harness diagram, I may be able to figure the hardware out that way too.
Old Nov 17, 2014 | 02:26 PM
  #4142
todd6027's Avatar
try here
http://mitsubishi-motors.kiev.ua/1/#...***%3DSNDFZL2M
Old Nov 27, 2014 | 11:02 PM
  #4143
PTK42792's Avatar
Powersteering pump bolts
I need all the bolts that mount the powersterring pump all I found was Part Number MD374022
Old Dec 2, 2014 | 04:55 AM
  #4144
bonsuz01's Avatar
Does Evo 8 has a Fuel Pump Relay Sensor and what is the part Number if so where it is located at?
Thanks
Old Dec 2, 2014 | 08:17 PM
  #4145
doncarbone's Avatar
Originally Posted by dagle
Anyone know if Lancer (non-evo) LCA's will work on an EVO? They look the same, I'm considering the Dorman aftermarket unit instead of paying 3x for OEM used.
front lower control arms between the Lancers and EVOs (02-06) are different.
Old Dec 3, 2014 | 11:31 PM
  #4146
jmb_silvester's Avatar
Hi Everyone,
Does the Camshaft oil seal and Crankshaft Oil seal are the same for evo 4 - 9?
and it would be nice if someone post the partnumber of those, thanks
Old Dec 4, 2014 | 04:55 PM
  #4147
fimotorsports's Avatar
Looking for the part number on Evo 8/9 turbo C clamp with bolt/nut. This clamp keeps the hotside attached to the chra.
Thanks
Old Dec 6, 2014 | 08:50 AM
  #4148
Evo_AK's Avatar
Veteran: Air Force
Originally Posted by jmb_silvester
Hi Everyone,
Rear Crank Seal - MD359158
Front Crank Seal - MD343563
Camshaft Seal - MD372536
Old Dec 6, 2014 | 08:52 AM
  #4149
Evo_AK's Avatar
Veteran: Air Force
Thanks
It doesn't have a sensor but the fuel pump relay is located on the metal bracket on the firewall, near the ABS module. The relay PN is MR514694
Old Dec 8, 2014 | 10:57 PM
  #4150
Thank you very much
Old Dec 15, 2014 | 11:17 PM
  #4151
rong.'s Avatar
AIRTREK front bumper
I found part numberts just wondering where I can order them from?
part numbers are
MR642446
CU4WFB
CUFB
AIRTREKFB
Thanks
Old Dec 24, 2014 | 07:45 AM
  #4152
haka's Avatar
I'm looking to confirm a part number for an evo 9 mr.
Rear passenger side ABS wheel sensor. is it MR493456?
cuz I ordered a replacement for mine that went bad, but I noticed the magnet tip was a short stubby style, where the one in the mechanics manual states the magnet tip should be a long style ~1 inch in length.
The one in the manual has the magnet tip like this one in the photo would the one in the link below work?
http://www.autopartswarehouse.com/sk...Passenger+Side
Old Jan 4, 2015 | 08:10 PM
  #4153
metallics2000's Avatar
Originally Posted by 1slowevoixmr
I've been browsing but cant find the part# of strut bar bolts. The two bolts in the middle..
Or anyone from here know the size?
MS240592 is the part number. I was also looking for them.
Old Jan 5, 2015 | 12:52 PM
  #4154
marcos.maldo1's Avatar
Can anyone tell me what the part # is for the Catalytic Converter from a JDM Evo VII?
Old Jan 5, 2015 | 06:22 PM
  #4155
Evo_AK's Avatar
Veteran: Air Force
I can if I had the VIN.
