All Part Number Request Go Here
Part #'s needed for the JDM rear bumper reinforcement and plate pieces to install my plate correctly on my JDM rear. 64001 comes up as the USDM piece and the JDM? I cant figure it out...
trying to find a part number for a evo 9 mr but basically it is part of a L shaped part with like weights on the ends that sits on top of the transmission which i believe is called a shift counter weight idk but it is what the shift cables connect to and its what moves the shifts forks inside the bell housing. i need the part number to that whole assembly. an illustrated parts breakdown would be better too
1999 Evo 6
Looking for part number for "back up lamp switch" (sensor on transmission for reverse lights to engage) on my 1999 Evo 6 GSR 5 speed manual. Anyone who can help just send me an inbox be very much appreciated
Plastic Undertray & Wheel Arch Fender Liner
Anyone know for sure the part numbers for the plastic undertray for Evo 9, & the passenger side wheel arch fender liner? IIRC, the plastic undertray is actually 3 pieces. Could be wrong. Also would need all the little plastic clips required to install these. Best place to buy them?
Rodent-Part number MN175430, same part number for both sides, and about $10 each
Kyoo-
http://www.mitsubishiparts.net/parts...iagram=6265030
All your parts are there, but you don't need 12 or 13, those actually go beneath the front bumper. At least that is for evo 9, but its real easy to find your parts on there. I use it to look up part numbers and then order through STM for their lower shipping up to me, but since you're in the states you can order from the site.
CJevoix-
http://www.mitsubishiparts.net/parts...iagram=6265325
All your parts should be there, same as above.
Kyoo-
CJevoix-
Kyoo-
CJevoix-
Kyoo-
CJevoix-
Need some more parts I can't seem to find.
Fender to bumper plastic inserts. One snaps the bumper into place, the other one is for a screw. Someone posted a link here for them but that link is broken.
The other pieces I need are for mounting the headlights. White plastic inserts that go in the radiator support and have a square head on top. The headlight tab goes on the square plastic insert.
Attached pic with yellow circles showing what I need.
Thanks! I always forget about STM and they did a nice job on those hard to find parts. I will post the part numbers here for future reference.
