All Part Number Request Go Here
Old Sep 12, 2014 | 09:54 AM
  #4126
kyoo's Avatar
is there a part that can act as a rubber stopgap for the o2 sensor hole under the passenger side seat?
also, what is the part # for the entire carpet (not mats) that covers the evo floor?
Old Sep 14, 2014 | 06:43 PM
  #4127
tsidrift1's Avatar
I need the part number for the mivec line and both banjo bolts.
Thanks!
Old Sep 22, 2014 | 12:32 PM
  #4128
C6C6CH3vo's Avatar
Manual Transaxle Control Shaft Boot
Need part number for the boot
* * * EDIT * * *
Disregard request of PN. Got it on order
Attached Thumbnails All Part Number Request Go Here-control-housing-shaft-boot.jpg
Old Sep 22, 2014 | 09:58 PM
  #4129
doncarbone's Avatar
looking for just the sprocket off the cam gear, the solenoid feed and the filter..
Old Sep 28, 2014 | 05:17 AM
  #4130
1slowevoixmr's Avatar
I've been browsing but cant find the part# of strut bar bolts. The two bolts in the middle..
Or anyone from here know the size?
Old Oct 5, 2014 | 05:48 AM
  #4131
Mas_egypt's Avatar
Hi guys , i need the part numbers for evo 5 and 6 ecu
Old Oct 5, 2014 | 06:03 AM
  #4132
todd6027's Avatar
evo 5
md356472
md360216
evo 6
mr420403
mr420543
mr514364
mr514365
just in case
evo7 also 4 plug but needs some wire swap to fit a 4
mr560648
mr560649
Old Oct 8, 2014 | 06:48 PM
  #4133
gallas's Avatar
Diff banjo bolt washers
Anyone know the part number for the front diff ACD banjo bolt crush washer that goes on the top of the diff and the washer itself has a thin black coating on the inside to seal?
I tried a normal crush washer that fit the banjo bolt but it didn't have that black inner ring and is leaking bad. Need help! Please and thank you.
Old Oct 9, 2014 | 05:50 AM
  #4134
todd6027's Avatar
MF660065 stock ones are just copper washers they dont have the inner ring those would be hydaulic bonded washers they are 14mm id
Old Oct 12, 2014 | 04:02 PM
  #4135
s4m's Avatar
s4m
This is great. Gonna help me out so much
Old Oct 13, 2014 | 11:52 AM
  #4136
haka's Avatar
anyone know what bolt is used to secure the passenger rear abs sensor in? I went to replace mine and the bolt was missing.
Old Oct 14, 2014 | 05:25 AM
  #4137
todd6027's Avatar
8x1.25mm and 20 mm thread length
MS240085
Old Oct 14, 2014 | 06:15 AM
  #4138
haka's Avatar
Awesome thank you so much.
Old Oct 31, 2014 | 02:39 PM
  #4139
dagle's Avatar
Anyone know if Lancer (non-evo) LCA's will work on an EVO? They look the same, I'm considering the Dorman aftermarket unit instead of paying 3x for OEM used.
Old Nov 4, 2014 | 10:58 AM
  #4140
06MREvo's Avatar
Alright guys, I am looking for a couple part #s for some firewall, harness mounting hardware!
This is for the section of harness that goes from the main fuse box along the driver's side frame rail, along the fire wall then through the firewall & under the dash. A lot of this harness is inside black plastic covers. There are (5) pieces of hardware total.
(1) 12mm bolt - Holds harness to driver's side frame rail, (3) 10mm nuts - Hold harness to firewall & (1) 10mm bolt - holds harness to firewall <<(Last bolt before it goes through the firewall & under the dash).
