All Part Number Request Go Here
Old Nov 13, 2010 | 08:30 PM
  #3406
a4rontran's Avatar
what would you call the plastic cover under the fender?
Old Nov 15, 2010 | 10:42 PM
  #3407
bigst1er's Avatar
^^ inner liner. Do you guys know the part number for the oem evo 8 side skirts?
Old Nov 22, 2010 | 12:00 PM
  #3408
acssa's Avatar
Camshaft position sensing cylinder
Part number for the Camshaft position sensing cylinder on evo 9.
It is the sensing cylinder bolting to the back of the exhaust cam.
Old Nov 24, 2010 | 05:26 PM
  #3409
Rex915's Avatar
I need the part number to the O Ring between the tranfer case and transmission on an Evo 8 please. I need the big one thats about 3" in diameter. I searched the threads, but everyone I saw was asking about the little one.
Old Nov 26, 2010 | 06:47 AM
  #3410
Rex915's Avatar
bump
Old Nov 27, 2010 | 09:21 PM
  #3411
oximuis's Avatar
Nice
Old Nov 29, 2010 | 04:10 AM
  #3412
EV0lut10n_8's Avatar
There's a removable pannel on the right of the dash that can be scene when the passenger door is open in the evo 8. I need that part. Any idea where to get it from?
Added a pic.
Old Nov 30, 2010 | 05:43 AM
  #3413
Jamesm331's Avatar
part # for oil filter housing?
cant seem to find it anywhere
Thank you.
Old Dec 3, 2010 | 07:18 PM
  #3414
Gordian79's Avatar
Need pn for washers that go on turbo drain tube bolts@oil pan.The ones with rubber seal in them.
Old Dec 6, 2010 | 02:41 PM
  #3415
hyeteck's Avatar
evo ix front radiator fan
Does anyone know the part number for the front radiator fan. Google keeps bringing me to the fan on the inside, i need the fan on the outisde. The one between the radiator and the intercooler. Its making gargling noises..lol Sounds like bearings are shot or something.
Old Dec 7, 2010 | 03:29 PM
  #3416
hyeteck's Avatar
anyone know the stock size of the pusher fan? (thickness and diameter)
Old Dec 7, 2010 | 06:43 PM
  #3417
adam_79_2005's Avatar
??? Are they not the same type of fan? I will look at mine for you when I get a chance.
Old Dec 8, 2010 | 06:44 AM
  #3418
atxMR's Avatar
The reason you're having trouble is because the fan you're refering to is not a radiator fan. It's the A/C condensor fan. Try doing a search for it instead.
Old Dec 8, 2010 | 10:33 AM
  #3419
EvoooB's Avatar
2006 Evo IX GSR SSL 5 sp. I need to get the main wiring harness that passes through the fire wall below and behind the intake manifold that connects to basically everything in the engine bay (Sensors, ACD ect...) I can supply a VIN # if needed. Does anyone know this part number is or can point me in the right direction. I've tried searching the parts website linked to MitsubishiParts.net and cant come up with anything. Thanks
Old Dec 8, 2010 | 11:14 PM
  #3420
sk82712's Avatar
06 Evo IX. The part that holds both the oil filter and one of the accessory belt pulleys (might be a tensioner IIRC).
Also, a cheap place to buy: 1760A190 gauge and pump assembly
