All Part Number Request Go Here
Old Jul 28, 2008 | 12:15 PM
  #2671
Spins4's Avatar
Originally Posted by TheDream
intercooler switch MR572674 14932 found on 03 Evo8 on the console.
Anybody know where to get this?
New or used? I can do both I took mine out when I "upgraded" to the 05 cupholder.
Old Jul 28, 2008 | 12:25 PM
  #2672
Spins4's Avatar
Originally Posted by EvoIXMR
Friday bump for bad boy bill !!!
Originally Posted by bank277
I was waving my telescopic magnet around the lawn and I found it. It flew about 8 feet. How lucky is that I should go to Vegas. I'll wait till I get the right tool before putting it back on, don't want to go through that again.
Whoa..well at least you did find it
Old Jul 29, 2008 | 06:25 AM
  #2673
TheDream's Avatar
I can do used if you have it, let me know
Old Jul 29, 2008 | 06:37 AM
  #2674
Spins4's Avatar
PM sent
Old Jul 29, 2008 | 07:03 AM
  #2675
MadCrix's Avatar
rear engine oil seal evo 8 gsr? thanks
Old Jul 29, 2008 | 07:06 AM
  #2676
Spins4's Avatar
Originally Posted by MadCrix
rear engine oil seal? thanks
As in the big rear crank seal?
MD359158
Old Jul 29, 2008 | 12:04 PM
  #2677
mfr122887's Avatar
I need a few part numbers:
Upper radiator pipe
Turbo Air Outlet tube bolt w/ washer
2 bolts for the radiator fan control assembly - hold the control unit to the shroud
The turbo coolant feed and drain rubber hoses w/ clamps
I can't get a straight answer for this last one. It is an 03 car but has a evo9 turbo. What oil drain and gaskets do I need. Thanks
Old Jul 30, 2008 | 07:46 AM
  #2678
mfr122887's Avatar
Upper radiator pipe
Need to order these parts as well as some others that I already have part numbers for.
Spins4 can you let me know if you have the above parts in stock along with 2x MF650114, 4x MF660065, MR450703, MR633538, and a set of studs, washers, and nuts for the exhaust manifold to head. 7 small nuts, washers, studs, and 2 large nuts, washers, and studs.
Is the part number I listed above, MR633538, indeed the trim peice that sits on the steering column where gauge pods are mounted to?
Thanks
Old Jul 30, 2008 | 09:00 AM
  #2679
Spins4's Avatar
Thanks
Best bet would be to PM me your "grocery list". I may not have time going back and forth to check the threads all the time. Damn I hate being a one man show sometimes
Old Jul 30, 2008 | 01:35 PM
  #2680
evo_skillz's Avatar
DOes anyone know the part # for this shift knob...EVO 7 (red)
I've been trying to find this shift knob everywhere, http://cgi.ebay.com/ebaymotors/JDM-L...mZ230274899452 but haven't had much luck finding the part number so i wasn't able to locate it on the mitsubishiparts.net website. I found someone selling it on ebay but it's just too much for a shift knob. I think the red shift knob would bring out the red accents inside the evo.
-Jonathan
Old Jul 30, 2008 | 01:47 PM
  #2681
EvoIXMR's Avatar
you do real good - like that monkey with the red suit vest on and the cymbals between the legs and drums around the neck, harmonica in the mouth. Rock on, Bill, rock on!
Old Jul 30, 2008 | 03:27 PM
  #2682
redevo58's Avatar
Did you try looking at the vedor japanparts.com? they are in the vedor section here.
Old Jul 30, 2008 | 03:47 PM
  #2683
evo_skillz's Avatar
^ thanks man.
Old Jul 30, 2008 | 04:03 PM
  #2684
inco9nito99's Avatar
...no such thing, someone anodized an OEM USDM RS knob (avail in silver or blue) to red.
Old Jul 30, 2008 | 06:15 PM
  #2685
mustangstewie's Avatar
Anyone know a part number for a 2006 Evo IX rear seat cupholder that is in the rear armrest or the number for the plugs in the cupholder that cover the two screws that hold it in the armrest? I sucked one up when I was cleaning the interior! I don't want to have to get a whole armrest...
