All Part Number Request Go Here
Old Nov 2, 2009 | 10:22 AM
  #3181
LI Evilution's Avatar
Originally Posted by 09Ralli
not sure of the parts name its on the rear drivers side, i beleive its called the wheel splash guard, it is the plastic part in the fender wheel well, also need the rear drivers side bumper bracket
The splash guard is MR954177 and list for $12.87. The bracket is MR574335 and list for $23.12
Old Nov 2, 2009 | 10:25 AM
  #3182
Originally Posted by JJsevol
Whats the part number for the passenger side skirt on ix 06 model. Thanks.
The number is MR954198 and list is $558.52
Old Nov 3, 2009 | 01:01 PM
  #3183
XSivPSI's Avatar
What is the difference between the following, besides the price:
MN156738 Gasket,t/c Oil Re $1.52
MR258477 Gasket,t/c Oil Re $1.22
Both are listed in this thread as the oil return pipe to turbo gasket. The MN one isn't in stock and the MR one is. I'm swapping an evo ix turbo onto my 8 which is why I need to know. TIA
Old Nov 4, 2009 | 08:46 AM
  #3184
The MN156738 is for the oil return pipe to the oil pan for 02-03 evos the MR258477 is for the oil return pipe to the turbo.
Old Nov 4, 2009 | 10:49 AM
  #3185
XSivPSI's Avatar
Fail...
Old Nov 4, 2009 | 10:51 AM
  #3186
XSivPSI's Avatar
Are these for the 8 or 9 turbo? I need the 9 part numbers...
1310A248 Pipe, Water Feed
1225A042 Tube, Oil Feed
Old Nov 5, 2009 | 11:27 AM
  #3187
VGergo's Avatar
Hello !
Woud some one please provide me the Evo 8 USDM cylinderhead part number ?
Is there any differences between the USDM JDM and EU cylinderhead on Evo8 ?
Thank You, Gergo
Old Nov 5, 2009 | 04:13 PM
  #3188
jpturbotalon's Avatar
evo 9 mr oil temp sensor part number
can anyone help me with the part number? i have been going back and forth with the dealer for this sensor and they said they dont know what im talking about. they keep sending me a water temp sensor. i believe the sensor is part of the oil drain plug.
thanks
jose
Old Nov 9, 2009 | 11:38 AM
  #3189
1310A248 and 1225A042 are both coming up at Evo 9 part numbers.
Old Nov 9, 2009 | 11:48 AM
  #3190
Originally Posted by VGergo
Hello !
Thank You, Gergo
The part number for a USDM Evo 8 cylinder head is MN155744 and list is $1700.13
Old Nov 10, 2009 | 05:56 AM
  #3191
wreckleford's Avatar
Is the pulley for the serpentine belt available seperately? If so, what is the part number? If nto, what is the part number for the entire tensioner assembly? Thanks.
Old Nov 12, 2009 | 05:52 PM
  #3192
TheMadScientist's Avatar
Can someone get me the part number for the bearing on the center differential the one on the transmission side of the center diff. Thanks for the help
Old Nov 14, 2009 | 10:47 AM
  #3193
warstang27's Avatar
im looking for the part number to the tube from the diverter valve to the intake so it can recirc, any help is appreciated, thanks!
Old Nov 25, 2009 | 05:29 PM
  #3194
demodeakin's Avatar
Intake Stud and Coolant Fitting Part # Please
While I was Pulling my Engine and removing the Manifolds my Intake Stud Stripped and a Brass Coolant fitting(Nipple) that goes into the head snapped off. I looked around and do not see that number listed I would like to get replacements before I get back to Guam so I dont have any Snags.
Deak
Last edited by demodeakin; Nov 26, 2009 at 01:10 AM. Reason: Added Pic of Stud and Coolant Fitting
Old Nov 27, 2009 | 01:08 PM
  #3195
gixxer1k's Avatar
first gear
need first gear part number. thanks
