All Part Number Request Go Here
Old Oct 5, 2011 | 06:03 AM
  #3586
babaz7's Avatar
i need part no. for evo 8 speed sensor i cant find it anywhere plz help!
evo 8 gsr 6 speed JDM
Old Oct 6, 2011 | 11:12 AM
  #3587
dizzle06ix's Avatar
I am looking for the orange light in the evo ix headlight, not the turn signal but the orange light that would flash if the alarm was going off or when unlocking or locking the doors of the car, also it is not the side marker just behind the headlight.
Old Oct 8, 2011 | 09:36 AM
  #3588
RussellM's Avatar
Plat Vendor
Originally Posted by Wellsfargo
I need a part number for the little steering wheel caps for the evo9 steering wheel. If you look at your steering wheel there should be 3 of them on each side. Thanks
No clue what you are referring to. Do you have a photo of the part? There is 1 cover on the back side, but nothing on the front that I'm aware of.
Just the bulb?
Old Oct 9, 2011 | 12:13 AM
  #3589
dizzle06ix's Avatar
Yes, just the bulb. All my other lights work fine.
Old Oct 9, 2011 | 01:27 AM
  #3590
Wellsfargo's Avatar
[QUOTE=RussellM;9657975]No clue what you are referring to. Do you have a photo of the part? There is 1 cover on the back side, but nothing on the front that I'm aware of. :dunno
this is what i was talking about..thanks
Old Oct 9, 2011 | 01:28 AM
  #3591
Wellsfargo's Avatar
part number for this
Old Oct 11, 2011 | 08:55 AM
  #3592
JFM13's Avatar
part number for driver side not the hinge but the lever that limits opening on the door
Old Oct 12, 2011 | 08:42 AM
  #3593
atcmac3's Avatar
i am looking for the lighted ring around the lock cylinder. 03 evo.
Old Oct 12, 2011 | 10:49 AM
  #3594
RussellM's Avatar
Plat Vendor
Please Follow the Link Below
http://www.mitsubishiparts.net/cart/?id=571&pn=5702A084
TRIM RING (very outside)
http://www.mitsubishiparts.net/cart/?id=571&pn=MN141252
IGNITION SWITCH - this has the bulb and everything in it.
http://www.mitsubishiparts.net/cart/?id=571&pn=MN101682
Old Oct 13, 2011 | 01:58 AM
  #3595
yasir's Avatar
I need part numbers for the following, for a 5-speed EVO gearbox :
1. FIRST GEAR
2. First to second syncro set
Thanks,
Yasir.
Old Oct 13, 2011 | 02:14 AM
  #3596
flo2877's Avatar
Ive been searching for the right name for this bolt and part number. I need the bolt for the Downpipe to 02 housing (the one that has a spring). I see a lot of part numbers but i just want to make sure thank you.
Old Oct 15, 2011 | 05:11 PM
  #3597
NOMIEZVR4's Avatar
Part number request :
100amp maxi fuses. Its the alternator fuse. It looks like it comes only in one piece with the 60amp fuse attached. This goes on top of the battery,positive terminal.
Old Oct 16, 2011 | 09:50 AM
  #3598
NOMIEZVR4's Avatar
anyone?
Old Oct 18, 2011 | 07:05 PM
  #3599
Luci4e56's Avatar
i need the following parts:
trunk liner (the full trunk thingy)
the black plastic piece at the end of the trunk
coin box
http://daxibeidelang.teasm.cn/Index.aspx
Old Oct 19, 2011 | 09:26 AM
  #3600
Wellsfargo's Avatar
. Anybody?
