All Part Number Request Go Here
Anyone know if this can be ordered separately? It's part of the shift linkage, it pulls the shaft in and out for 5th gear and reverse I believe. Mine keeps falling off leaving me without first gear =[
Can any Identify this bolt part number? I believe it's camber bolt?
Uploaded with ImageShack.us
Any help would be greatly appreciated.
Valve cover gasket - MD340535 (production date 2002.12.1 to 2005.07.3) / MD372906 (production date 2005.08.1 to 2006.11.3)
Spark plug well gasket (x4) - MD186785 (production date 2002.12.1 to 2005.07.3) / MD373583 (production date 2005.08.1 to 2006.11.3)
Half moon seal - MD372348
Left could be MR623814 or MR642945, and right could be MR623816 or MR642947. I'm not sure what distinguishes which cars get which part numbers. If you want, PM me your VIN number and I can find out for sure. That's the only way to be absolutely sure you're getting the original part for the car.
Can you get me a picture of where in the car that sits? Unfortunately, it does not appear it can be bought separately but I can tell you better if I know exactly where it goes.
The part number for PNC 62046R is MR574317. The name of this part is "PLATE,FR BUMPER,UPR RH". This is for the right hand (passenger) side. The driver side part is PNC 62046L and part number MR574316.
i need the part number for this "clip", headed to store in an hour!
https://www.evolutionm.net/forums/at...ulbs-step6.jpg
https://www.evolutionm.net/forums/780798-post11.html
Does anyone have the part number for the Vacuum/boost line Tee fitting that is situated on the passenger side of the engine bay by the intake manifold? The fitting is connected to the FPR, intake manifold and boost gauge tubing. The tee fitting is plastic with a brass orifice within it on the boost gauge side. This fitting is probably only found on 8/9 MR's or others that have the factory boost gauge installed.
Thanks!
Thanks!
