All Part Number Request Go Here
Old Mar 1, 2013 | 11:26 AM
  #3886
AdrenalineRush's Avatar
Steering Column Fell Off! HELP!
See the pics below its self explanatory. The column keeps falling out of the welded metal cut outs. Now one of the brackets (pic # 3/4) is cracked. Does anyone have a part number for this?? I can't seem to find one :/ Other than getting that replaced the column doesn't seem to line up very well with brackets. No matter how hard I pull the steering wheel towards my body the cut outs barely fit into the slotted brackets fastened to the top of the dash area.
Old Mar 1, 2013 | 11:41 AM
  #3887
MrSquirr3l's Avatar
if the brackets are steel you can tack weld it in spot. or call a dealership they will give you the part number if you ask them.
Old Mar 1, 2013 | 11:47 AM
  #3888
SilverShadow03's Avatar
Try Mitsubishiparts.net
or source one out of a wrecked evo.
Old Mar 1, 2013 | 12:03 PM
  #3889
Well I don't know what the part is called that's the problem so I can't get a part number for it...
Old Mar 1, 2013 | 05:12 PM
  #3890
Bump for help on a part number for the small slotted bracket.
Old Mar 1, 2013 | 05:22 PM
  #3891
golgo13's Avatar
EvoM Community Team
Veteran: Navy
VIII right, probably the same as a IX though?
Which one of these?
Old Mar 1, 2013 | 05:51 PM
  #3892
Which one of these?
See it's the bracket that bolt #45272 connects into BUT on my car the bracket itself isn't attached to the welded peoce just below 45127A
Old Mar 1, 2013 | 06:00 PM
  #3893
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Mitsubishi thinks it's the whole column.
MN101704
$232.59 + $34 shipping from Mitsubishiparts.net
That PNC 45162 (PLATE, STEERING COLUMN NUT) doesn't have a part number associated with it.
Old Mar 1, 2013 | 06:01 PM
  #3894
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I say buy a used column off the forums.
Old Mar 1, 2013 | 06:11 PM
  #3895
MN101704
Where did you get that price and part # I was looking on MitsuParts for forever lol. The local dealership wanted $370 for the steering column assembly
Old Mar 1, 2013 | 06:24 PM
  #3896
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I got the part number from the ASA software and then I plugged it into the mitsubishiparts.net website.
Old Mar 5, 2013 | 09:34 AM
  #3897
DVS_DAN's Avatar
Hey, I could use some help figuring out a couple bolt sizes. I'm missing the two bolts at the top of my bumper (not the two clips) and the two bolts for the center of the strut tower. Any help would be great so i can pick them up from the hardware store or wherever.
*Used a buddy's car to figure out bolt sizes
Old Mar 12, 2013 | 05:54 PM
  #3898
kyoo's Avatar
Can someone help me with the side blinkers - it's called so many different things it's hard to pinpoint exactly what I need:
it's this, except the stock, WHITE version:
Lancershop said it's this but the part # is wrong: http://www.lancershop.com/customer/p...3&cat=0&page=2
edit - well i found em for ten bucks but after some soul searching i decided to keep these orange ones. part # would still be nice if someone's got it
Old Mar 15, 2013 | 03:19 PM
  #3899
doncarbone's Avatar
For 04-06 Ralliart
Need help finding an adapter/seal type part that goes between the transmission bell housing/motor to increase spacing
The issue I am having is that my new flywheel (clutchmasters aluminum) is thicker than stock and the clutch cover is rubbing against the inside of the bellhousing...I need to squeeze somehow an extra 0.25" or so.
My mechanic thinks there is some sort of an adapter that might go between the tranny/motor to give the inside of the bellhousing a bit of extra room...my old motor (OZ rally) has something like this although it's very thin, thinner than 0.25".
Does anyone know if this part exists and if so what is it's part number and its specs?
Thanks
Old Mar 16, 2013 | 12:47 AM
  #3900
EvoVIIII's Avatar
MR222646 ACD hydraulic pump
