All Part Number Request Go Here
Old Apr 23, 2013 | 12:16 PM
  #3916
todd6027's Avatar
Originally Posted by stowasaurus
could replace my camber bolt with any 14mm camber bolt since theyre the same size or are they unique to our cars?
front top camber bolt has a shoulder so you can adjust the camber with stock shocks , if your using coilovers with adj top hats then normal bolt will suffice .
rear ones also have a bigger offset washer for adjustment
Old Apr 24, 2013 | 08:05 PM
  #3917
bonlamicq's Avatar
hi, maybe you can help me
I'm looking for the left ACD sensor and some type of disk or like that with small spaces, it is ubicated at the wheel
mitsubishi evo 2005 m, the sensor and that thing was smashed in an car accident.
thanks
Old Apr 26, 2013 | 04:09 AM
  #3918
todd6027's Avatar
abs sensor left hand MR569147 and cv joint abs ring cant be had separate so it would be a full shaft ,need a chassis number for that
Old Apr 26, 2013 | 11:56 AM
  #3919
jospi's Avatar
Mitsubishi part number carbon Vortex Generator Evo VIII MR fq-400
Hi,
I am driving a Mitsu Evo IX in Belgium (Europe). I want to install the carbon vortex generator of the EVO VIII MR fq-400 on my car. Is there anybody who can tell me what's the original Mitsubishi part number of this generator?
And the Evo 9 MR FQ360 Carbon Fibre Front Lip, is here the original Part number known?
Many thx, Johan
Old May 4, 2013 | 09:34 AM
  #3920
littleevo8's Avatar
i really need the bolts that go to the power steering pump!!!! or atleast the thread pitch and size
Old May 4, 2013 | 12:01 PM
  #3921
littleevo8's Avatar
i need some power steering bolts
Old May 8, 2013 | 10:16 AM
  #3922
06ssdevo9's Avatar
What are the part numbers for mounting oem 9 oil cooler. The bracket and bolts.
Old May 13, 2013 | 03:57 PM
  #3923
WEB187's Avatar
Do you guys know if the passenger side inner tie rod is the same on a 2006 EVO MR as the rest of the 06 EVOs? Also do you know the part number? I told the parts wear house what i needed but he sent me the wrong part, (happens all the time with MR parts) so this time i have to get the exact part number. Thank for any help you can give me.
Old May 13, 2013 | 09:26 PM
  #3924
MrJuls's Avatar
Does anybody have the part number for the 4th gear syncro for the Evo IX GSR?
Old May 22, 2013 | 08:15 AM
  #3925
EvoBroMA's Avatar
looking for part #s for the Evo IX Special Edition Lip and the 3 under pieces that go with it.
Old May 28, 2013 | 08:37 PM
  #3926
TURBO_S2K's Avatar
can I get the part numbers for these??
oem heater labels
oem evo 8 floor mats
Old Jun 3, 2013 | 08:22 PM
  #3927
morgeesplease's Avatar
Wink crossmember bolt part #
hi, can I get help with the Mitsy part number for the Evo6 large front crossmember bolt to the chassis, I beleive m12 x 1.25 x 160mm , code 32166D.
Also lateral crossmember bolts for the rear, look like m12 x 1.25 x 40/50, code 32166E & 32166C.
Thanks in advance. Want to restore a bad purchase into a good car!
Old Jun 4, 2013 | 10:59 AM
  #3928
ProPilot04's Avatar
Anyone know the part number for the engine wiring harness?
06 Evo 9 MR (6-speed).
Old Jun 8, 2013 | 05:05 PM
  #3929
Racerx9146's Avatar
Lifter oil bridge part number please
Hello
Just got my cylinder head back from the machine shop. They took off this piece below and I assume it needs a gasket but I cannot find the part number in any of the online part catalogs.Help!
Thanks Daron
Old Jun 9, 2013 | 01:39 AM
  #3930
EvilEvo69's Avatar
When I bought my 03 Evo 8 GSR the trunk came completely bare for some reason as in all of the fabric and trunk board and everything. It is currently just a big empty metal trunk and would like to know everything I need to get it back to what it was. I already have on my list MR572609 (trunk board), MN124891 (trunk mat), and was wondering what exactly comes with MR444269 (trunk trim). I also found MR572500, and MR975477HC which are clip and instrument clip from what i understand. do i need these?
What I am asking is What is every part i need to get my bare metal trunk back to its original oem state? I appreciate any and all help.
I can provide pics soon of my bare trunk if it will help you all figure out exactly what is needed.
