All Part Number Request Go Here
Old Oct 21, 2011 | 02:43 PM
  #3601
Rex915's Avatar
looking for the last 2 part numbers to complete my order at mitsubishiparts.net: the single bolt that goes on the cross member (not the side that has 2 bolts). The bottom 3 bolts that tie the transfer case to the transmission. Thanks in advance
Old Oct 22, 2011 | 02:34 PM
  #3602
killercd4G63's Avatar
Veteran: Army
2 different size nuts on the Exhaust manifold that holds the turbo manifold to the head.
The 2 big ones on the sides and the smaller ones in the center.
Thanks!
Old Oct 22, 2011 | 02:56 PM
  #3603
Rex915's Avatar
Thanks!
hope this helps
http://www.streettunedmotorsports.co...it_dsm_evo.htm
Old Oct 23, 2011 | 06:07 AM
  #3604
Veteran: Army
Originally Posted by Rex915
Ahhh thanks man. You're a Evo saver!
Old Oct 23, 2011 | 10:51 PM
  #3605
mr06's Avatar
hello, could I get the part number for the dash tray by the ashtray. I would like to get rid of my MR gauges and need something to put there.
Thanks
Old Oct 25, 2011 | 11:49 AM
  #3606
19.5PSI's Avatar
part number for the front and rear banjo bolt and the copper washer? im seeing a few different part number so im not sure which is the correct one.
for 2003 evo 8.
thanks
Old Oct 31, 2011 | 12:45 PM
  #3607
s.lamoureux's Avatar
looking for the part number for an evo 9 MR center console cover. The silver top piece with ashtray and cig lighter...
Old Oct 31, 2011 | 07:16 PM
  #3608
bnr34rb26dett's Avatar
bolts that hold this down
http://www.streettunedmotorsports.co...heel_cover.htm
and
the center 2 bolts that hold the strut tower bar.
Old Oct 31, 2011 | 07:43 PM
  #3609
vmrevo9's Avatar
Veteran: Air Force
I actually have a weird request. I'm looking for the bolts that attach the subframe to the unibody. It's located towards the rear of the LCA's. Anybody ever order these or have any good info on them?
Old Nov 1, 2011 | 06:16 AM
  #3610
todd6027's Avatar
mb303360 12mm x 152mm long x 2 bolts are the rearmost and longest ones then theres the rest
mb809344 12mm x105mm long X 4 bolts
washers are separate 12 of each
ms450044 spring
mf450007 flat
Old Nov 1, 2011 | 09:11 AM
  #3611
and
this?
Old Nov 3, 2011 | 04:24 AM
  #3612
todd6027's Avatar
this?
2 of MF140056
2 of MD012109
and
2 of MS240592
Old Nov 3, 2011 | 07:03 AM
  #3613
03mitsevo's Avatar
thanks
Old Nov 3, 2011 | 07:59 PM
  #3614
Originally Posted by todd6027
2 of MF140056
2 of MD012109
and
2 of MS240592
thank u!
Old Nov 5, 2011 | 07:09 AM
  #3615
selecta's Avatar
a/c "radiator", driver side wheel well lining, hood latch vertical support bar
