All Part Number Request Go Here
Old Oct 19, 2015 | 10:22 AM
  #4246
dyablo's Avatar
Need a price for the passenger fender liner plastic thing plus the plastic screws used to secure it. I believe its part number MR954176. Shipped to 92203
Old Oct 23, 2015 | 07:53 AM
  #4247
vbturbo2's Avatar
Originally Posted by Ricoswave
Need the part number for the metal cup that slips over the inboard side of the drivers side front driveshaft ( interfaces with the seal at the transmission). Just bought a used axle and its bent up pretty good, no way it will hold fluid. Hoping its actually available, it did slide right off.
Its not listed separate in the catalog.
albert
Old Oct 23, 2015 | 07:57 AM
  #4248
vbturbo2's Avatar
I can do 38.00 on the part but shipping will kill the price. Retail is 55.00 so your local dealer might be the best bet if they can give you like a 10% discount it would probably be cheaper than my price plus shipping. Big box without folding really bad.
Albert
Old Oct 24, 2015 | 05:21 AM
  #4249
cam280's Avatar
EVO 6 CP9A owners know the other cars you can get your spares off!
Hi, found a great site that shows not only the part but also the cars the part goes on
http://www.partsbase.org/mitsubishi/...00-cp9a-sngf2/
Old Nov 6, 2015 | 04:22 PM
  #4250
newuser03's Avatar
I need the part number
I need the part# for the drain and fill plugs for my 6-speed transmission. I changed the transmission fluid today, but I messed up the two plugs because I didn't have the proper Allen Key (Hexagon). Do you guys have the part # or know where I can buy/order them?
6 speed transmission EVO 8 MR.
Old Nov 8, 2015 | 06:45 PM
  #4251
jmb_silvester's Avatar
Hi everyone,
does anyone know the description and parnumber of this...
Old Nov 9, 2015 | 10:31 AM
  #4252
PRican_480's Avatar
can you PM me the part number for the 2005 evo 8 Positive battery terminal and the positive battery terminal fuse block thank you
Old Nov 18, 2015 | 04:02 PM
  #4253
kamote2000's Avatar
Part number for Evap purge solenoid located on the intake manifold. Thanks!
Old Nov 19, 2015 | 09:44 AM
  #4254
Thore's Avatar
MR560952
This?
Old Nov 19, 2015 | 12:15 PM
  #4255
EvoooB's Avatar
2006 Evo IX - I'm looking for the front upper grille mesh and the tin frame work that is attached to it also. Looks like it might be P/N 6402A033 & 6402A053, can anyone help confirm? I do not need the Mitsu emblem in the center. Thanks
Old Nov 20, 2015 | 05:55 PM
  #4256
kamote2000's Avatar
Originally Posted by Thore
MR560952
This?
Thank You Sir!
Old Dec 20, 2015 | 08:38 AM
  #4257
moyassine's Avatar
good stuff. it helped me. thank you sir
Old Dec 27, 2015 | 12:37 PM
  #4258
boostincincy's Avatar
the Plastic Clip inside the fuel door, because when I pull the gas tab in the car, the gas door doesn't pop open anymore, unless someone is there to pry it open while I hold it.
And also, the passenger seat, bolt that holds the belt clip to the seat. So if you're sitting in the seat, the bolt to your left that holds the clip on.
thanks please!!
Old Dec 28, 2015 | 05:27 AM
  #4259
kamote2000's Avatar
Part number for the evap canister ventilation solenoid thanks! ��
Old Dec 28, 2015 | 02:12 PM
  #4260
egg_baLLa's Avatar
Part number for:
1. Parking light bulb
2. Fog light bulb
3. The light bulb on the side of the rear bumper
Thanks!
