All Part Number Request Go Here
Old May 30, 2018 | 09:56 AM
  #4471
Originally Posted by paul4x4
This car was jacked up in the wrong place at some point in its life. I am thinking these rails can be replaced by a pro, right? I believe it's just a cosmetic issue at this point, but it sure is annoying to see. Anyone have OEM part numbers for these, or know where I can find them?
Paul. Wouldnt worry about replacing that part. There is likely more to it than it looks. Unlikely that crushing damage has affected anything
The part no. maybe this but not entirely sure: MR65054 L & R
Old May 30, 2018 | 11:48 AM
  #4472
kyoo's Avatar
bolts that go into the subframe brace that crosses the downpipe? head is a 14mm
Old May 30, 2018 | 12:09 PM
  #4473
Hey Sam. Looks like the part no. is Mitsubishi MS240295 (maybe an M8 bolt but not sure of the length)
(item 32166)
Old May 31, 2018 | 12:22 AM
  #4474
seb_delgado's Avatar
Ralliart Buschur Racing Catback Exhaust & Evo X Leather Recaro Seats
need Buschur Racing Catback Exhaust 3inch SS & Evo X Leather Recaro Seats or Canadian Evo X Final Edition Seats for my 2011 Ralliart Sportback
Old May 31, 2018 | 01:57 AM
  #4475
jmb_silvester's Avatar
Hi Everyone,
Does anyone knows the part number of Evo9 Turbo Actuator? TIA
Old May 31, 2018 | 05:57 AM
  #4476
Originally Posted by jmb_silvester
Hi Everyone,
The part no. I come up with is: MN153089 (please double check before ordering) (item 12501)
Old May 31, 2018 | 06:21 PM
  #4477
Hi MinusPrevious,
Thanks for the quick reply, I did checked Item 12501 and it shows 2 partnumbers: 1515A056 , MN153089
I searched both partnumber in the net and it says both are dump valve(atuator).
So which should i used for ordering, i just wanna make sure that the one im going to order is correct so that there is no hassle for the seller and the buyer(me).
TIA.
Old May 31, 2018 | 06:52 PM
  #4478
N1MR0D's Avatar
Rear Upper control arm
Ok guys!
I have a difficult one. Rear upper wishbone control arm. I need the 2 bolts that screw the front of the arm into the body (red circles) and I need the bolts that hold the bracket on to the frame of the car for the rear mount (green oval and arrows indicating the bolts direction). Not the bolt that connects the control arm to the bracket, but the bolts that connect the bracket to the frame.
On the SE model how the bolts that hold the brake air guides on?
And the bolts that hold the front sway bar bracket on to the lower control arms?
Any help would be AMAZING! Thank you guys!
Old May 31, 2018 | 07:10 PM
  #4479
Originally Posted by N1MR0D
Ok guys!
The red circled bolts come up as: MF241284 (substituted part no.)
The green oval bolts for the upper arm come up as: MR297337 (item no. 41393). But per your note, this is not what youre looking for? (see diag below)
Front sway bar brkt to control arm bolt = MF241284 (substituted part no.) same as the red circled bolt
Please confirm before ordering
Old Jun 1, 2018 | 04:57 AM
  #4480
N1MR0D's Avatar
Correct Minus. I am NOT looking for item #41393. This bolt connects to a bracket that is mounted to the frame of the car. I need the bolts that attach that bracket to the frame. I cannot find that bracket or bolts for that matter ANYWHERE.
Old Jun 1, 2018 | 06:13 AM
  #4481
Is it the bolts noted in the pic below w/the black & green arrows?
Old Jun 1, 2018 | 06:50 AM
  #4482
Could be this view here: (item 41393BB)
Part no.s show to be: MF241284
Old Jun 1, 2018 | 08:11 AM
  #4483
N1MR0D's Avatar
YES!!!! That is it! Thank you Minus!
Old Jun 1, 2018 | 11:34 AM
  #4484
N1MR0D's Avatar
To clarify It was the black arrowed bolt. The Yellow arrow is pointing to a subframe bolt. Thank you again Minus. What view did you find the bolt picture on?
Old Jun 1, 2018 | 12:03 PM
  #4485
Not sure if I follow your question, but the 2 bolts were found in this view (see arrows). They share the same part no.
